  • 4 weeks later...
I was checking out Kn's Factory in Japan (part of Kanagawa Nissan dealership), because they made a rare strut brace for the Y34 that I have, and found all these Nismo bits for Juke, Note and Leaf.
http://www.kanagawa-nissan.co.jp/kns2/tuning/nismo/leaf/performancepackage.html
http://www.kanagawa-nissan.co.jp/kns2/nismocar/noto/notomenu.html
http://www.kanagawa-nissan.co.jp/kns2/nismocar/juke/juke.html
  • 1 month later...
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
