Over the last coupla years, I've managed to pick up
nismo key, fashion lighter, paperwork case, floormats, clear front & side indicators, fuel pump, billet oil cap, high-pressure radiator cap, timing belt, LM GT4 18" bronze rims, s-tune wheel lug nut set, s-tune air valve cap set, 480cc injectors, solid shifter, dash cluster, engine mounts
I did have the nismo 3-gauge dash cluster, but I've since replaced with a GTR MFD (non-nismo).
All parts have seemed like the highest quality to me. I'm more than happy to buy Nismo. The key was probably the hardest - I nearly picked one up in 2007, but fell through - and recently managed to pick one up uncut. I'm always on the look-out for nismo parts :)
  • 4 weeks later...
Need a keen eye here guys. Looking at buying this Nismo Duracon shifter which looks hella cheap:
http://www.ebay.com.au/itm/NISMO-Duracon-Gear-Shift-Knob-Manual-Black-Nissan-/110878560606?pt=AU_Car_Parts_Accessories&hash=item19d0e0915e
It looks the goods, the packaging looks legit (I own another Nismo shifter) but the price is throwing me off. What do you guys think?
http://www.ebay.com....=item19d0e0915e
i have the same one and got mine for that price through performance wise.. was told it was genuine, looked good in packaging, feels good in the car.. still not 100% its 100% genuine, but it does do the job! and hasnt worn crazily in the 4 months or so ive had it for. so im not really fussed either way. also purchased other parts through performance wise so i tend to believe its genuine.. they may have over stocked them in Japan and now offloading them cheap?
I <3 Nismo gear, it's just faultless
So far I've tracked down and installed
Nismo Ti Strut Brace
Nismo LMGT4's in Silver
Nismo S-Tune suspension
Nismo Rear Member Brace Kit
Nismo Floor Brace Set
Nismo Lug Nuts
Nismo Sports Clutch
Nismo Timing Belt
Nismo Intercooler Piping Set
Nismo Steering Rack Bush Set
Nismo Leather Gear Knob
Worth every cent, the gear is just superb :)
Read the first part of your post and thought the second part haha.
Well if Nismo makes a better umbrella than Alfa Romeo, I think I'll go for it...
Hmmm, but not rubber boots Kristian lol
Is there a more comprehensive catalogue than ^^^ ?
I'm surprised at how many ppl here have such sizeable lists!!!
Yeah, there's alot of ppl with empty walllets after looking throught that catalogue
Better add mine,
Nismo short shift kit
nismo radiator cap
nismo cold air intake
nismo oil cap
nismo oil cooler
nismo n1 vents
nismo brake master cylinder
nismo injectors
nismo clutch master cylinder
nismo suspension link components (various - not complete set-up though)
nismo gearbox mounts
nismo engine mounts
nismo fuel pump
and soon to have nismo mfd v2
Probarly a few more that i've missed...
Edited by wedge_r34gtr
Slightly off topic but how to get...
I can get these easily if you need it.
For my ER34
I have S-tune suspension (Willing to Sell)
Speed meter
S-Tune front and rear strut tower bars
S-Tune front and rear stabilizers
Coppermix Twinplate clutch.
S-tune rear tower bar for R32 (Willing to sell)
Side markers
Probably a few things I forgot to mention.
After oil and radiator cap I'll be complete.
Easy to source if there is stock !!
http://shop.nissan.c...duct/detail/515
More here and I can help with purchase but would advise not to buy clothing without trying on first as clothing sizes are for mighty midgets.
http://shop.nissan.c...itemCategory/50
http://shop.nissan.c...itemCategory/51
http://shop.nissan.c...itemCategory/52
http://shop.nissan.c...itemCategory/61
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
