At a guess - 18x9.5 +12...
I'm still curious as to who bought my old LMGT4s from Import Monster, as they were getting sprayed black from memory...
Close.. 18x10.5 +15 ;)
Bought them from Import Monster as well. Aaron said he found a pair on Yahoo Auctions about 6 months ago and then another pair recently to make a set as they barely ever come up for sale in 18x10.5 +15.
  • 4 months later...
