You just buy them, no exchange needed. Guess they go round stealing them off old wrecks and old Oem stock!
Can't work out why one side of the bar is braced extra, but guess they know.
They're still in production. They wouldn't use used parts.
All parts genuine
Currently own:
Lmgt4 white 18x7.5 +30
Lmgt4 bronze 18x9 +22
Lmgt4 silver 18x9.5 +12
Black: still to collect 18x10.5 +15
Nismo design key uncut - 8 point
Nismo horn button
Nismo gt shift knobs rubber and titanium
Nismo r tune front bar fiberglass - s15
Nismo 740cc injectors x4
Nismo 555cc injectors x6
Nismo gt LSD pro tt model
Nismo floor mats 5 piece set
Nismo speedo 260km/hr
Nismo timing belt
Nismo main and conrod bearing sets
Nismo number plate surround
Nismo wheel nuts
Nismo valve caps
Nismo horns (came on s15 lol)
Nismo t shirts x3
Plus a few other bits
Sold:
2 of those horrible duracon gear knobs
Fuel filler cover that was junk
One set of lm gt3 in silver 17x7.5 17x8.5
Lost:
nismo lanyard
Nismo hat
Would like to buy
Lm gt4 in 19 inch 9.5 or 10.5 width
Nismo inlet manifold
Nismo outlet pipes in carbon from r34 clubman spec, surely they will produce these
Nismo suppercoppermix twin plate c spec
Nismo intercooler and hard pipes (just because)
Edited by Gts30t
Wish whoever left one spam, now my comment looks out of place and weird :/
Lol ^^
If I ever sell my GTR, I'd like to think that the Nismo key goes with it, as an uncut blank.
They're badges above and below the key. They're made by Nissan, but I can't find the Part#.
  • 1 month later...
  • 1 month later...
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
