Can't see where you're located but I asked NISMO about the seats and they told me that only a NISMO tech can install them. I guess they said that per warranty,etc.
I really wanted to do this but I'm set on removing and storing my seats so I install carbon seats
Just had a quick count on my r34 gtr, 26 items on there ranging from intercooler to oil cap to much to list and bore you with,I like those parts always a good fit and top quality, down side not so cheap .
Edited by EM1
I'll start at the front
Nismo intercooler
Nismo piping kit
Nismo plenum
Nismo air flow meters
Nismo air inlet pipe
Nismo air duct
Nismo timing belt
Nismo engine/gearbox mounts
Nismo oil pan baffle set
Nismo oil separator
Nismo fuel pump
Nismo super copper mix clutch
Nismo GT taillight set
Nismo smoked indicator set
Nismo multi function display/fitted from factory
Nismo oil cap / rad cap
Nismo floor mats
Nismo titanium shift knob
Nismo sway bar kit
Nismo s tune suspension
Nismo performance damper kit
Nismo latest ti strut brace
Nismo big operating cylinder
Nismo clutch hose
Nismo brake lines
Nismo carbon fibre blade
And that's it doing an engine build todate and most other parts are hks
Inj,oil pump pistons crank,I could just keep going should be running in the
next month.
Edited by EM1
I'm drooling over this thread
Only a small list at the moment but will be expanding on it (after reading this thread lol)
Nismo leather gear knob
Nismo clear front indicators
Nismo clear side indicators
Nismo car seat covers
Nismo LMGT4 rims (delivered just yesterday :D )
Nismo oil cap
Nismo radiator cap
Nismo fuel cap
On the cards
Nismo wheel nuts
Nismo air valve caps
Nismo floor mats
Nismo engine mounts
Nismo gearbox mounts
And whatever other Nismo stuff I can get my hands on :P
aiiight........ I will kick start this off
nismo racing radiator cap - (P/N:21430-RS012)
nengun-1221-02-nismo-clutch_pedal_bracke
nismo reinforced clutch pedal bracket for BNR32 (P/N:46550-RS585)
nismo white meter set for center console for BNR32 (sorry for the bad photo will have to take a better one)
nismo GT shift knob (titanium version) (P/N:32865-RN013)
nismo intake collector kit (P/N:24820-RN583)
nismo 320kph Speedometer (P/N:24820-RN583)
nismo Super Coppermix Twin Plate clutch (BNR32 94 - pull type) rated @ 640ps 9807N (P/N:3002B-RS599)
nismo Big operating slave cylinder for BNR32 - pull type (P/N:30620-RSR40)
nismo Racing release fork pivot (P/N:30537-RS581)
I have more but will post that later on ;)
  • Like 1
  • 4 weeks later...
Was going thru some stuff and found my nismo key that has been cut but didnt work. Might see if a locksmith can smooth it up a bit and get it working...
* Was it copied off an existing key or off the key code sourced from computer?
* Try a spare blank first and cut that. If it works then use the Nismo key. The cheap copy can be a valet key for the boot. The Nismo one is too valuable to sacrifice of course.
Terry: looking at it I think the profile each side is not 100% aligned properly, it was cut from an original key. It should buff up ok and come back to that nismo bling we all know and love. I was just thinking how really old worn keys usually work well and maybe this one could be smoothed out and made a bit looser.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
