Yes, it's embossed Simon in the modern day n-i-s-m-o logo on the other side.
Part# KWA10-50710 (more fancy and detailed than KWA10-50720)
I've sent Marko to you about your LMGT1 set.
Look after him won't you?
Meanwhile, I don't know what this old school font is called but for my R32 GT-R, I'm collecting them...
I'm after the radiator cap one (if anyone has one f/s), and I think I need to sift through this thread again too...
  • Like 1
I saw an old nismo radiator cap at Nisswreck today in SA. Although its not to the condition that you would like.
Brad,
I'm about to get some of the old style high-temp-resistant stickers made up for those rad caps.
They degraded pretty badly over time - heat cycles.
Once made, I can show you how it (the replica) looks and whether or not it's for sale.
I would only sell it to a person with a 1.2-1.3 pressure rad cap anyway; and would take no responsibility for how the buyer's rad cap behaves.
Can anyone tell me anything about these shocks? Came out of my r32 gtr but i dont think they are the factory shocks are they? They look as old as the car though. Nismo part numbers 56110-rn585 and 56210-rn585. They are made by KYB.
post-72069-0-82900600-1412072908_thumb.jpgpost-72069-0-39379800-1412072925_thumb.jpgpost-72069-0-97168000-1412072951_thumb.jpg
They felt quite firm but i cant compare them to standard gtr shocks as i wouldnt know how the standard ones are, they almost seemed firmer than the BC BR's i replaced them with though. yeah ive got no idea how old they are but im sure they dont ride the same as they did when new.
Parts -
Nismo front bar
Nismo side skirts and rear under spoiler
Nismo pillar garnish
Nismo carbon wing blade
Nismo titanium shift knob
Nismo LM-GT mag wheels 18x10+20(the only size and offset manufactured)
Nismo diffuser fin set
post-135234-0-39095900-1412570099_thumb.jpgpost-135234-0-79905500-1412570169_thumb.jpg
Edited by NURVOUS
  • Like 2
I have similar suspicions, I'm a big fan of the gt500 edition though in both black and anodised.
Thanks
I suspect those magnesium wheels even weigh less than my LMGT4 GT500 18x9.5
Congrats Bueller.
Happy to weigh my GT500 if you Bueller is willing too next time the tyres are off :)
I do believe they are lighter even at 18x10 +20
Yeah for sure, as it's still wearing the original factory delivered tyres from 2002 it could be a while off though....
  • Like 1
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
