  • 3 weeks later...
  • 3 weeks later...
Nismo C/F Twin Blade Rear Wing on the R33 GT-R
Six bolts to adjust on installation instead of the usual four.
It is a nice piece.
Millimetre perfect.
Nismo Side Skirts to go on next.
  • Like 6
I'm not sure l0ckym. It was swapped by V-Spec Performance along with a Nismo Ti strut brace in exchange for Magnesium TE37s that came across on the 33R.
V-Spec Performance in Melbourne has had them.
Gulp - just looked up vspec's website.
I'll be peeling a lot of potatoes yet :-(
51 minutes ago, Terry_GT-R34 said:
Yes, steel.
The coating is easily scratched though, so it's best to spray the inside of the Nismo socket with Rust-oleum Peelcoat rubberized spray.
 Thank you Terry.
I'm tossing up between Work wheel nuts ($280) or these Nismo ones ($195). Crazy expensive for bloody wheel nuts!
11 hours ago, ShortCircuit said:
 Thank you Terry.
Have a look at McGard Splinedrive wheel nuts, I bought mine off Amazon (back when dollar was better), were a much better value option. Go the "installation kit". Work & BBS (& others) actually resell McGard nuts (Work Royal nuts for example).
Fit with heaps of clearance to my Lmgt4's
  • Like 2
 Thank you so much! That pricing is much more reasonable! Only problem is I really wanted black wheel nuts and I can't find them in black. :(
I may have to settle for chrome.
-edit- I found black ones but the pricing isn't as good! :(
Edited by ShortCircuit
Caved in and bought the Nismo wheel nuts. Didn't want any colour other than black and didn't want to fork out over $200 for wheel nuts. (Seems a little crazy to me).
I will take on Terry's recommendations to keep them scratch free.
  • Like 1
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
