37 minutes ago, MrFijiGold said:
Cheers Pete.
I bought this same clutch for my previous BNR34 & loved it. For the new one, it was a no brainer which clutch to choose..
From what some blokes said about busting the factory box with my 3.2 , I think mainly the 3rd  gear ,  I was a bit spooked about smashing though the gears,  but the coppermix handled it and a few other crazy blokes gave it a wack and no problem :)
So my dear son has given me this Nismo Torch/Tool Kit
He says, "If you know how to get this to work, you can keep it".
And I can't get it to work ay! I tested the batteries - tick. I have reversed polarity - tick. I have turned the battery compartment upside down - tick. I changed the batteries - tick. I have looked for some hidden button and partially turned the collar - tick.
So can my brains trust here, on SAU help?
Otherwise, I might have to give it back - lol.
I think with flash light they use the body to transfer power so when u screw up the ends make sure no grease interferes. Or oring.
Nice collection of brochures. A high definition photo of every page would be a god blessing on SAU [emoji12]
  • Like 2
P1010769.JPGTerry mine had a small plastic disc between the battery pack and the globe,and u turn the globe end to turn it on.P1010768.JPG
Edited by I gotta R34gtr v-spec
add picture
  • Like 1
19x9.5" +12 LMGT4 in Victoria for a 5-figure sum
...and...
LMGT4 sold by a different Victorian back to Japan for another 5-figure sum
...and...
This buying behaviour pulls the values of 18" LMGT1, LMGT2 and LMGT3 northwards.
  • Like 2
On 11/20/2016 at 6:37 PM, gtrj said:
I wonder how much more expensive LMGT1's can get. Wish I could afford a set :(
You guys must have crazy import tax or these guys are blatantly ripping you off. These have been on the auctions for a long time at 279800¥ which is like 3300 AUD. Obviously have to add shipping costs but you guys are way closer to japan than us and it's only 500 to ship here lol.
Edited by JTCC
  • Like 1
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
