  • 3 weeks later...
A sea turtle has been rescued in Thailand. After stomach lavage, it was revealed that the turtle had swallowed many coins which is why it was finding it difficult to stay buoyant enough to  breathe.
It has been named "OMSIN", which in Thai, means Piggybank. That's how I found OMSIN. :)
Backwards Bankpiggy  NISMO , lol
  • Like 1
Thought i had posted here but it appears not.... the Headrest on the interior has since been fixed as has the horn button been straightened haha, was a quick snap when instaling. Still restoring the foot rest.
IMG_20161125_1950473.thumb.jpg.af91a48005db5664669f7aa2184baa16.jpg1481531512845867067855.thumb.jpg.714c4564757a223cae19968ff997dbc9.jpgIMG_20161125_1949145.thumb.jpg.91fb13b939ab95afeca4db87d0e46e9b.jpg
  • Like 3
  • 4 weeks later...
received_10154670280817659.jpeg off topic ( people hear have a good keen eye ) so i have NO luck sourcing a part number or even finding one for sale for an OEM factory 1996 GT-R option full carbon fiber interior trim.
Been looking 3month mad for this now.
By far this must the the rarest item to come by and i want it. !
http://www.r33gt-r.com/p/nissan-oem-catalog-1996-r33-skyline.html?m=1
Image is the best as it gets.
Surely someone has seen one or have one, would be nice to get the spotlight on it. [emoji4]
  • Like 2
Did they only make r34 one? I cant seem to find them on the website for any model. I've been on the fence about one for the 32. I know attain makes one. Curious to see how nismo would design one if they made it. Your's looks pretty clean and tasteful.
Hey Ryan,
They make them for 32,33 and 34. Pics are a few pages back, there's been nothing officially posted by Nismo about them yet. Its like they don't want your money :)
Those brake guides look expensive, i better start saving...
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
