http://shop.nissan.c...brandCategory/8
I will not be held responsible for any money spent...
Check out the iPhone covers!!!
Kristian, can we organise a "group buy"? or something to buy some merchandise?
Or if not, is it difficult to get this stuff?
N1 handbrake - no leather, like a lightweight BOSS ;)
Ohhh nice.
They say that "imitation is the greatest form of flattery"...
...but this one isn't imitation...
Very fortunate that this was sold privately here on SAU - Good on SAU! :thumbsup:
And many thanks Marcus for Nismo's Opening/Closing Times!
I'm sure they're useful to not just myself.
Bobby, Nick & Luke, I'm going to spruce up the old Nismo Oil Cap and increase its appeal (and value) by double - lol
I only have a small NISMO problem, with the following NISMO items fitted to my car
AFMs
Intake collector manifold (Group buy, on it's way from Japan)
Cluth pedal bracket
RB26 oil pump (not N1)
Instrument cluster
Centre gauges
Leather gear shift knob
Front strut brace with BMCS
LMGT2s
Wheel nuts
Tyre valve caps
Lighter
Braided clutch line
Engine and gearbox mounts
Air filter
Engine oil cap
Fuel filler cap cover
Floor mats
I have the Weldina Version 2 rear muffler (oblong shaped) and it's so damned quiet! Does anyone have a version 1 that wants to swap?
I have a nismo weldinda ne-1... Not sure if that is what your talking about, as it is pretty quite also..
ahh yea i think i remeber the oblong one you guys are talking about...
mine is abit different.. same as the ztune i believe but not in titanium...
That's the same one, the version 2 muffler is oblong, the version 1 is round (and a bit louder apparently). Rear muffler is interchangeable...
Ahh yea, sorry I was confusing it with the muffler tip shape.
Mm interesting stuff, might need to see if I can source one.. I like the sound of mine as is, but it is very quite.. But then again I don't want it too loud either ha.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
