Driving along today at about 40-50km/hr my car turned into a subaru...
It started chugging and sounding like a boxer. I limped it home (about 5km) and called my tuner.
I tried starting it again but when I got it started, i saw thick white smoke bellowing out of my exhaust.
I've recently had the following fitted to my car (by Garage 101, great guys btw)...by recent i mean a week ago. All items are brand new.
GT3071r with braided oil & water lines
550cc injectors
VDO fuel pump
Haltech Platinum Pro (MAP sensor ecu so no AFM)
New NPC clutch
I'm led to believe an oil seal on the turbo has given way but i have no idea how this could happen (if it were the case). The new turbo was fitted with new genuine garret gaskets.
A few other points to make:
The car was fitted with Yellow jacket coilpacks about a year ago
Spark plugs were gapped as it was missfiring on the dyno (this fixed it)
Please any advice would be great. I'm racking my brains as to what the problem could be.
https://www.sau.com.au/forums/topic/401703-r33-sounds-like-a-boxer/
  • Replies 46
yeah sounds like its just fouled the plugs...check if your plugs are fouled, put new ones if they are
then suss out things that could cause it to run rich, boost leaks or pipes/hoses that may have blown off, chances are its something simple.
No spark in one of the cylinders. Check your coilpack loom plugs are all plugged in properly. Then start disconnecting and reconnecting coil pack plugs until you find the one that doesn't make a difference to the engine sound - there's your culprit.
After working out which cylinder isn't firing, swap that coilpack with another one to see if the problem follows the coilpack or stays with the same cylinder - if it follows then it's a faulty coilpack, if it stays put then it is a dead spark plug or loom plug issue.
Usually either an injector not firing or an igniter giving no spark.
Given that you said you have a rich petrol smell, more likely to be ignition.
Regardless, check all your ignition & injector connections are properly connected.
If that's all good I'd lean towards fouled plugs.
Anything else will probably mean taking the car back to Danny
thanks for the replies guys.
If its a fouled spark plug or an ignition issue then what would be causing the white smoke?
I'll take a look at the plugs and coilpacks tomorrow when theres some light. What should I be looking for on the plugs?
see if they are all black and sooty basically...
This or any oil/coolant deposits. Post up a pic of them. Try keep them in order.
Chances are u will need a new set of plugs to help diagnose.
If it still runs on 5 cylinders with new spark plugs u need to diagnose which cylinder is misfiring by disconnecting one coilpack at a time with the engine running. The one that doesnt change is ur dud cylinder. Chances are though when u pull the spark plugs u will be able to tell which cylinder is faulty.
yellowjackets.........
Please...you can say the same thing about Splitfires, JJR and any other brand of coilpack. They all have their issues occasionally - at least Paul stands behind his product.
If u think the hardest diagnosis is removing plugs theres something wrong. Yes u can do the disconnection first. Its just the order i typed it in. But masses of white smoke to mee requires checking plug condition. Spark plugs tell u alot
+1 that Jez.. If your plugs are fouled its gunna rn like crap anyway making harder to diagnose anything..chances are if you drove 5km like that with a rich fuel smell from your exhaust, regardless of the problem the plugs are going to be fouled by now..
If you're talking ignition, then yes, removing the plugs...considering you remove coilpacks to get to them...is the harder diagnosis. I don't see the point to removing plugs if you find a dud coilpack and can suss it out straight away? No time is wasted if you find out the coilpacks are fine.
Considering it's only just started happening, his plugs can still be fine. I had a faulty coilpack that gave me the exact same symptoms as OP and I ran on it for weeks. Replaced the coilpack and presto, 6 cylinders again. Ran beautifully. Replaced sparkies at their next interval and they all looked fine.
Was urs pumping out white smoke?
Lol at driving on 5 cylinders for weeks
It wasn't always on 5 cylinders, I probably should have explained that in more detail - the dud coilpack would come back to life after about 5 minutes of idling or driving. It was my daily driver and replacement coilpacks were still a couple weeks away so was happy to keep up the routine, despite my car sounding like a WRX and going like an Excel.
I wasn't blowing white smoke, but that could be an unrelated problem he has...isn't that usually coolant/water being burnt off when warmed up or just normal on cold start?
Check the coils first dammit! lol
Could be several problems actually, he might still have slight headgasket issues - the fuel smell is simply unburnt fuel due to no firing in one of the cylinders.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
