I've just taken out my sparkies and coilpacks.
Attached are pictures of the 6 spark plugs. Spark plug 1 refers to the cylinder closest to the radiator.
I checked the plugs like you guys said and the only one that was slightly different was the 2nd plug. It was black and had a very distinct smell of fuel. it was ever so slightly moist.
Anyway I checked my coolant levels and it hasn't dropped. Checked my oil levels and oil cap (no white residue on the oil cap).
I'm getting really worried about the car now...I spent so long researching before I did this build making sure i was doing it right.
Once again, your help is greatly appreciated!
http://s1259.photobucket.com/albums/ii542/kevlo948/
  • Replies 46
I've just wasted half an hour
FYP brah. Did you bother to try the suggestion I made...you know...the easiest test of all...coilpack pulling with the engine running? No? Oh, that might be why you didn't find the problem. Nevermind, you might notice my post one day.
Blue Steel, Ferrari, Le Tigre...they're the same face!
haha sorry birds I actually did what you said straight after the post. To behonest I must have missed your post.
Anyway I've replaced the second spark plug and tested the coilpacks. Second coilpack is dead!
So now im thinking the white mist is unburnt fuel from the second cylinder (the smell is incredibly strong)
Sorry Birds I didnt mean to disregard your suggestion. I pretty much woke up this morning and started on it.
I'll be ordering Splitfires and I'll let you guys know.
Once again thank you guys muchly!
Yeah Birds at least you can Raise Fist and give the whole " I told you so!!! " Look
thats exactly what imagined him doing too...:laugh:
On the upside, at least you know your spark plugs are in GC...cmon lets be honest here if you are checking your coilpacks you may as well pull your plugs out for a quick check while you're there right...
right Birds :unsure:
Haha all good dude, it's just that I've posted similar things in other help threads and then it's always the last thing OP tries or they spend hundreds of dollars misdiagnosing the problem!!! Only so much ignored advice I can take! :)
Glad you got it worked out. Did you also try swapping the coilpacks around to see if the problem follows the coilpack rather than stays with the cylinder? This is just as important to work out, don't want to be replacing coilpacks for nothing in case you have no power going to that loom plug.
And yes Artz no harm checking spark plugs while coilpacks are out :P Although if you keep your valley cover off like I do, you can do the coilpack iagnosis without lifting a single screwdriver ;)
haha ok fine i guess i deserve the flaming... :(
let it rip boys ><
No flaming man... These guys are happy it's gunna be fixed... Everyone has to start somewhere, I'm learning as I go and take
These threads as a good thing :)
lol..your such a drama queen :yes:
but I like keeping my cover on.. ..1..makes it easier for my OCD that wants me to hose done my engine bay daily..2..cause it looks the sexy
Just a side note too, might help to drop Paul at Performance Wise a line and see if he'll sell you a single replacement coil pack. Saves you forking out $600 for a whole new set of Splitfires when you only have one dud. Nothing wrong with (functional) Yellow Jackets in powerful applications, I run them in my R33 (258rwkw) and S15 (287rwkw) without issue.
In fact, the S15 was back to back tested on the same dyno with Splitfires followed by YJs. The graphs were basically the same, with both brands being incrementally better than each other in different parts of the rev range. Overall they were on par.
Please...you can say the same thing about Splitfires, JJR and any other brand of coilpack. They all have their issues occasionally - at least Paul stands behind his product.
Except that the death rates for cheap coils seems to be about 5 times as high as for Splitfires or new Nissan coils. At least from where I'm sitting.
He's great to deal with mate, and that's exactly what I meant by "stands behind his product". And why I'm always happy to recommend them. In contrast, you can find stories on here of other companies telling people where to go or having a lot of trouble getting faulty parts replaced.
Same reason I bought a Hypergear turbo - Stao will help you long after you have purchased his product and that's what matters most to me as a consumer. You just saved $600 :)
  • 9 months later...
thread revive.. and i really hope someone can help me out here, as im pretty much in the same boat as the op.
bit of info about the car:
1996 r33 gtst
basic rebuilt rb25, acl bearings, arp studs, metal head gasket, tomei poncams..
vipec v44 ecu (MAP sensor)
atr43g3
nismo 555cc
splitfire coilpacks
last tuned at 340~rwhp on 15-17psi.
so i know its something that i have done to it as the car ran fine until a few months ago it developed an oil leak and i had to pull the motor out to replace the rear main and front crank seals, re-tighten the headgasket and change the oil pan.
turned the key for the first time today and it sounds exactly like a wrx. runs really rough, strong smell of petrol (coming from i think the engine bay aswell as the exhaust), doesnt idle steadily, and i found it difficult to notice the difference when pulling some of the coilpack plugs off.
pulled the brand new plugs out. 1 2 3 4 and 6 were as sooty as a chimney, while 5 was actually wet and smelled of petrol.also all the tops of the pistons looked wet.
the vipec ECU is throwing out fault code 46 - "AN temp 2 error high value" (air intake sensor exceeding 5v). apparently if this value is exceeded it puts the car into safe mode and might be contributing or causing my rb25 to act like a boxer motor.
does anyone know where the IAT sensor is located?
might see if i can get borrow some coil packs, and i will probably look into the coilpack loom. no obvious nicks or cuts in it from memory or do the wires just break apart from the plugs?
RB25s do not have an intake air temp sensor. So if your Vipec was originally installed with one, then only you or the installer would know where it was put. In the intercooler cold pipe or perhaps into the plenum are the only places that make sense. If however, your Vipec expects there to be an IAT but it never had one fitted......then the signal line on the ECU is probably sitting high at 5V and it might complain the way you report.
My guess is that no-one would be that foolish, so I'd suggest the wire is probably not connected.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
