Item 1:
Forsale: Soundstream SW-12SE Arachnid Series 12" Subwoofer x 2 (DUAL)(With Sony Dual Enclosure)(Plug n Play)
Delivery & Condition: Pick up, Meet up, No Post Due of Size
Contact: 0400 928 949, pm here or email to [email protected]
Item Condition: Used (As New), Good Condition
Price & Condition: $300 Negotiable
Details:
12" Dual 4-ohm Arachnid Series Subwoofer
- Power Handling:
Peak: 500 watts
RMS: 250 watts
- Black zirconium coated injection cone woofer
- NBR Rubber surround
- Vented pole piece for added heat dissipation
- Nickel Plated 8ga. Compression Wire Terminal
- Suspension integrated tinsel leads
- Silver Texture Coat Finish on Stamped
- Poly cotton spider
- Stamped steel basket
- 2" KSV Kapton voice coil
- Sensitivity: 85 dB
- Mounting Depth: 5.125"
http://www.soundstre...rs/arachnid.htm
Pics:
Item 2:
Forsale: Defi Link Advance CR Meter (Boost Gauge) White + Defi-Link Control Unit II (Complete wiring, solenoid)(Plug n Play)(Packaged)(Genuine not copy)
Delivery & Condition: Pick up, Meet up, Post (At Buyers Expenses)
Item Condition: Used (As New), Good Condition, Working before pulled out of the car
Price & Condition: $350 Negotiable (The Lot) (Normally $275+ for the gauge alone without the controller)
Details:
Defi Boost Gauge Details:
-Display Unit: -100kPa ~ +200kPa
-Interactive communication advanced system is implemented.
-Flat glass and precise graduation scale give more needle accuracy and high visibility.
-Gauges can be controlled from distance with the included switch unit.
-Opening and closing modes can be selected from 2 variations.
-The illumination at night (I had it on Green Colour Setting)
-The needle pointer driven by original stepping motor has a smooth instantaneous response to rapid acceleration of high performance vehicles.
-The microcontroller calibrates up to 270 degree angle in 3027 - 4600 segments (0.088°- 0.059°), and provides accurate vehicle information.
-Self-diagnosis system turns the warning LED on to indicate any wire disconnection, short circuit and serial communication errors.
-Warning by buzzer sound when the warning LED is on (buzzer sound can be turned on / off).
-Peak value and warning value during driving are stored. Driving data can be stored and replayed up to 3 minutes.
-A mounting bracket, meter cup, regular position bezel are provided with this product.
Defi-Link Control Unit II Details:
Defi-Link Control Unit II is a necessary controller to install Defi-Link Meters, Defi-Link Meter BFs, and Defi-Link Displays. Up to 7 gauges and displays can be connected and controlled by one Control Unit II. The name of the connection system is "Defi-Link System."
Control Unit II Version 2.0
Parts NO.DF05002
Defi-Link System allows gauges and displays to be attached to Defi-Link Control Unit II with a single "DAISY CHAIN" wiring system.
Links: http://www.defi-shop.../summary_unit2/
http://www.defi-shop...it2/spec_unit2/
http://www.ebay.com....f#ht_1132wt_901
Pics:
Item 3:
Up for sale is
- Honda Civic FD 2006-2010 double din dash (Brand new $215) - $160 ono
- Kenwood DDX8039 Multimedia (7"Wide Double-DIN Size Monitor with Radio / DVD Audio / DVD Video / WMA / MP3 / DiVX / AAC Receiver / USB + iPod connectivity) - $450 ono
Pick up from Georges Hall NSW or postage at buyer's expense.
Call or sms 0412 189 219.
Pics:
Item 4:
Forsale: Polished Front Strut Brace (Bar) for MKIV Toyota Supra
Delivery & Condition: Pick up, Meet up, Post (Buyers expenses)
Item Condition: Used, Good Condition
Price & Condition: $60 neg
Pics:
Item 5:
Forsale: Hi Flow RB25Det/VG30 Turbo with Dump Pipe and oil braided line
Delivery & Condition: Pick up, Meet up (only Due of size and weight)
Item Condition: Might need rebuild. Unknown Issue (Possible Seals)
Price & Condition: $150 neg
Pics:
Item 6:
Forsale: Stock Z32 N/A Airbox
Price & Condition: $50 neg
Pics:
  • 3 weeks later...
  • 5 months later...
*********Items Updated**********
Item 1:
Price & Condition: Currently on Auction at Ebay http://www.ebay.com.au/itm/130817588853?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649#ht_1618wt_1393
$130 starting bid price no reserve
Details:
http://www.defi-shop.com/products/end/dl_meter/summary_dlm/
Parts NO.DF05002
Links: http://www.defi-shop.com/products/end/unit2/summary_unit2/
http://www.defi-shop.com/products/end/unit2/spec_unit2/
Pics:
Item 2:
Pics:
Item 3:
Pics:
Item 4:
BLITZ BLOW OFF VALVE (BOV) RB26DETT Nissan Skyline GTR R32 R33 R34 260RS Stagea
BLITZ SS Super Sound
Blow Off Valves (BOV) (Pair)
For
Nissan Skyline
R32
R33
R34
Nissan Stagea
WGNC34 260RS
For RB26DETT TWIN TURBO
Was working perfectly on my Stagea before removal
These are genuine JDM Parts
Price & Condition: Currently on Auction at http://www.ebay.com.au/itm/130817583894?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649#ht_1846wt_1393
Starting bid price at $200 no reserve
Item 5:
Nissan Skyline R33 GTR
Also Fits
Nissan Stagea 260RS
Centre Console Gauge Unit
Front Torque
Oil Temp
Boost Pressure
Carbon Look Surround
Genuine
Made in Japan
(Removal Due of Nismo Gauge Unit Upgrade)
(Was working fine before removal)
Price & Condition: Currently on Auction at http://www.ebay.com.au/itm/130817605565?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649#ht_1940wt_1397
Starting bid price from $50 no reserve
Item 6:
Nissan Skyline R32
RB20DET
Factory ECU
OEM Stock Unit
Genuine
Made in Japan
(Removal Due of Aftermarket ECU Upgrade)
(Perfect for Ecu Flashing or Nistune)
Price & Condition: Currently on Auction at http://www.ebay.com.au/itm/130817600974?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649#ht_1526wt_1397
Item 7:
Nissan Skyline R32
RB20DET
Air-Flow Meter
AFM
Green Label
Genuine
Made in Japan
(Removal Due of Z32 AFM Upgrades)
Price & Condition: Currently on Auction at http://www.ebay.com.au/itm/130817598865?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649#ht_1603wt_1395
Starting bid price at $50
R33 Skyline GTR Centre Console OEM Gauge **SOLD**
R32 RB20DET OEM Factory ECU **SOLD**
Edited by GGGTS4
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
