I checked your printout - sorry i cant add anything more with my limited knowledge. AFAICT its looks reasonable. Ask in the Vic forum what suspension place is recommended in your area. I've never got the service I was looking for in a chain like Pedders or Bob Jane.
Tyrepower ringwood seems to be the place to go, long history of perfect aligning. Makes sense, lower overheads from a smaller shop and less professionalism (cough bobjane massive wastes of space).
Will be dropping it off tomorrow so will see what they find.
I use them too.
+1mm per wheel station seems about right.
I just read that you have only 32 psi in 30 profile KU36s. Pump them up to 38 and try that. They don't work below 36 in my opinion. I run my 235/45-17 KU36s at 36 - 38. When they have fallen to 34 I start to wonder why the car isn't going where I want it to.
36 - 38 psi won't wear out the middle of the tyre either. I never have, over several sets of KU36.
Too much toe in not enough castor.
You want more like 6deg castor
Toe in zero front and rear
I am running 3 deg neg camber front and rear for the track but it turns in great on the street as well and no undue wear so far(4000km). Try at lest 1 -2 deg neg or whatever you can get with your setup
[quote name='R33-
Terry_GT-R34
Tyre pressure is? - 32psi
GTR-34A - Like i said they're brand new tyres Kuhmo KU36 18/30/265 all round,....
Is the tyre still rubbing on full right lock?
When tyres are cold, is there any improvement by pumping up tyres to 38-39 instead of 32?
Your profile is only 30 remember.
I was running 285s on a 10.5 rim with AD08s, never had any issues at all with tram lining in the dry. The car would jump around a little if there was a major deviation in the road, but any car will do that.
Wasn't running too much camber and just a good alignment from Racepace (their own mechanics do it), same alignment i had when i took it to the track, so it was all purpose and worked. I ran 32psi in them for street duties.
I did have alignments done by a few other places, everytime they just couldn't get it right and it would drive like rubbish. Perhaps give a GTR expert a go, rather than places that work on all cars? :)
That said in the wet it would tram line a little bit with such wide tyres, as the AD08s are especially wide due to a nice sidewall, however it really wasn't a major problem at all, even when i had 265 semi's on the car (was a little more squirmish in the wet, slight movement in the dry, overall still easy driven) :)
Tyreplus sorry, on bond st just down from barry bangay. or maybe he did mean tyrepower in croydon, but he said it was close. i'll ask again :D
Ash thanks for the suggestion although this place (barry) the head guy knows GTRs, and he said the printouts for the align match what he knows. I might ask for the specifics to post on here to compare, although obviously a 32 is different to a 33, plus all the other stuff you've done to your car :D
Would the fact my tyres are a starting to get low make a difference?
Thanks for all the responses guys - i'm going to get a third opinion by a one of the specialists recommended.
I'm tossing up between tyrepower ringwood or racepace
I'll post back results here once done.
  • 4 weeks later...
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
