Sorry about the delay in getting these completed after the little tempter on Scotty's car.
As some of you may know; this is a copy of the OX Motortsport Chassis brace. Mine are TIG welded in Chromoly tube (as opposed to the alloy construction of the OX Motorsport version) and painted black.
The weight of these is almost identical to the Alloy version.
It really stiffens up the front end of the M35, allowing your suspension & swaybars to work their best.
It is a great value little mod, that is basically invisible once fitted.
It comes with all mounting hardware and can be fitted at home with basic hand tools in around 20 mins.
I have some completed, and waiting paint right now, and I'm asking $150 each; delivered anywhere in Australia. They'll be ready to go early next week.
Pics straight off the jig;
post-61153-0-32259300-1338781669_thumb.jpg post-61153-0-71556800-1338781717_thumb.jpgpost-61153-0-73489600-1338781820_thumb.jpg
post-61153-0-38782800-1338781747_thumb.jpgpost-61153-0-35672600-1338781771_thumb.jpgpost-61153-0-05764300-1338781794_thumb.jpg
There is another brace for the centre of the rear subframe, but it is extremely labour intensive to manufacture, and I'm not comfortable with the price what I'd need to charge to make it worthwhile.
If there is enough interest, I will also be manufacturing a brace for the rear mounting points of the rear crossmember, but this will be a little further down the track.
Let me know in this thread, or by PM if you would like one of these.
Also; A big thanks to both Iain for his generosity in loaning me the braces, and Craig for his assistance.
Edited by Daleo
https://www.sau.com.au/forums/topic/401750-nm35-stagea-front-chassis-brace/
guy's this is instantly noticeable........for those of you with stupidly firm BC suspension you may need to back off your shock rates a little.
It's my favourite upgrade other than the sway bars......it's basically the same improvement again.
MOOOORRRRREEEE G'SSSSSSS
Whew! Spent the whole day in the garage, giving my Ebay TIG welder a hiding!
All PM's replied, and people who requested PM's; check your inbox.
Thanks for your support everyone; I don't think you'll be disappointed.
Cheers, Dale.
Count me in. I'll be in for the rear crossmember brace too if you do one. Any possibility of a strut brace that fits around the raised plenum?
Anyone interested in a GB for the OX centre rear subframe bar if Dale isn't making them? Should be this one: http://www.oxmotorsports.co.jp/7_9.html
At current exchange rates they're ~$170 plus shipping. I guess getting the bends right is the big issue Dale?
Anyone interested in a GB for the OX centre rear subframe bar if Dale isn't making them? Should be this one: http://www.oxmotorsp....co.jp/7_9.html
Ok Ryan, you might have to wait a couple of weeks, as I've sold all eight that I have completed. The demand is more than I was expecting.
Yeah, the issue is putting quite tight bends in such thin wall tubing without collapsing the wall. To keep them light, I'm using 1.6mm wall CrMo tube; it's fearsomely stiff, so I have to lay a decent bit of heat into it to bend it without kinking. I've made a couple of dies for the bender, but I'm just not very happy with the result.
No worries Dale, no mad panic.
Figures with the bends. Worth doing or should we look at OX?
Cool, thanks. I'll wait to hear from you on the others, and I'll see if anyone else is interested in the third bar.
Looking forward to another package expertly wrapped by your kids! :rofl2:
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
