Just confirming these fit the V35 coupe?
If so hit me up with a PM for payment details if there are any left :D
I'm in Brisbane
They do fit the V35 coupe.
Let me check tonight to see if I have enough material to make you one, & I'll PM you.
To everyone who is waiting; apologies for the delay. With my car out of action presently, it's making it very difficult to move materials around; so I'm running a little behind.
Your patience is appreciated, it won't be too much longer.
Feel free to PM me if you have any concerns.
Cheers, Dale.
@Dale, any chance you can ship to NZ? would they fit a PNM35?
It will definitely fit a PNM35; I made one for Alex's (PN Mad) HKS fed beast in the last run.
The only issue will be delivery cost; I can get a shipping quote, and them we can go from there. Shoot me a PM to remind me, and I'll get back to you later in the week.
Cheers, Dale.
OK update;
Apologies for the delays everyone, but I'm getting very close to finished on these.
I'm hoping to have everything buttoned up and in the post early next week.
If anyone has any concerns; please PM me.
Thanks for your ongoing patience.
Update;
A busy day on Sunday,
After blasting this morning;
And cooling off late this afternoon.
These will be going in the post in the next few days; keep your eyes peeled for a tracking PM.
Edited by Daleo
Letting the apprentice loose on the wrapping? Or did you paint mine a 'limited edition' colour?
It's called 'BigKev pink'
My mate likes to call it "Dog dick pink" :whistling:
Lol, nah; but lets just say it won't be getting damaged in transit.
Nice one. I'd expect no less.
I still have flashbacks to the sway bars, struggling to get them unwrapped! :P
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
