Hey guys,
I am currently chasing an Auto variant of variant of the following cars
R32 coupe, R33 Coupe or 180sx (SR)
The car needs to be Running and at least have an Rwc (Rego optional)
Not looking for a show car but don't want a bomb either (meaning not looking to soend 8-10k)
Just want something simple and clean.
Please text or call on 0426252535 if you have somethibg.
Cheers,
Kai
Edited by V3N0M
https://www.sau.com.au/forums/topic/401762-wtb-r32r33180sx-qld/
