DRIVELINE
STILLWAY (japan) RB24DET Stroker
GTR crank
GTR rods
Custom HKS pistons
Engine block -unknown mods
Solid head conversion + unknown mods
274/274 cams
JUN Adjustable cam gears
850cc injectors
nismo fuel reg
HKS twin spark ignition system
BOSCH 040 internal pick-up
BOSCH 044 external feed
2L surge tank
GATES racing timing belt n new pulleys
standard coil packs
modded factory plenum
3" mandrel exhaust turbo to tip
custom intercooler piping and intake pipe (big G)
all internal mods are unknown as motor was built in Japan by STILLWAY company
Trust mid-mount twin scroll manifold
Trust T67-25G 10cm
Trust 48mm ext gate
OS Geiken 3-plate clutch
RB25 gearbox
custom tail shaft
standard R200 4.3 LSD -welded
standard 6bolt s13 drive shafts
Cooling
52mm alloy radiator
2x Maradyne 2350cfm each fans
B&M supercooler oil cooler
perma-cool relo kit
Standard ECU re-map by DR DRIFT
Power: 350kw@21psi on Powerplus 110 race fuel
Electronic
5 gauge AUTOMETER custom dash
-oil psi
-oil temp
-boost
-water temp
-3 5/8" rev tacho
switches for ignition, start, fans etc etc
Body
widened front guards
rear guards chopped
30mm widebody skins
topstage rear flares ontop of widebody
BA XR8 GT bonnet bulge
2UP headlight clear lenses
MARS side indicators
MARS 180sx front bar indicators
URAS N+ aero front bar
s13 aero skirts
Wheels
SSR Viennas
17x10 -19 (F) 215/40/17
17x10 -39 ® 235/45/17 (with 20mm 4->5 conv spacers)
skids: 17x10 D1Rs
Suspension
HKS HyperD fronts 10kg springs
TEIN HR rears 6kg
Adjustable caster rods
HEYMAN knuckles (troy)
GKTECH lock spacers
alloy cradle lockers
Interior
RECARO SR3 drivers
whatevers available on the day passengers seat
SABELT 3" ratchet harness drivers
SABELT 2" passengers...meh
back seats
rear seatbelts LOL
*soon to be all removed when i can F$%$Ked*
car is still in development stage as been building for last 3yrs and only seen 2 track days since
cbf writing up a whole story on the car guys so heres a picture story
where it all began as a CA18DE here shown jus with coilovers n wheels
removed bashed doors n chucked on doors from my old bent s13 n a bit of nismo/garden edge love
went reverse panda
at this stage it was CA18DE+T with a full trust TD05 kit...2 weeks later blew the headgasket so freshened up the motor chucked some JUN Cams in n was ready to go back in
then the RB24 popped up for sale from my mate, whom brought it down in a 32 drag/wangan car from japan was making 370kw on pump98 with a TO4Z with massive boost leak n coil packs cutting down
so the CA got ditched n then started the long n draining story of this silvia build
pictured here with its first turbo setup...HOLSET HX35W of a diesel truck engine
new fans n radiator
just b4 calder drift attack
ummm...dont ask
new look for matsuri n more rear offset
love my dash...
n finally....
this is the exact same engine from the s15 in the very popular youtube video lol
  • Like 1
Great first post for a build thread - if only the rest had all that detail and information, well done.
This car would be a riot to drive too, love it
thanks bro yer it is a handful n loves wide open throttle :)
wow , so is there anything left to do to the car apart from taking trim out?
pretty much only thing left...left the trim in there because initial plan was to keep it a street car but lost my licence too many times n thought otherwise
Interesting car mate, can I ask how it feels with the spring rates you have? Seems a little odd. Nice build though!
thanks bud
car feels stupidly quick, i like more of a soft setting to maintain full traction under full throttle even my front dampeners are on level 2 out of the 12 available lol
i still gotta get camber arms n toe arms for the rear n wind it out to about +.05 camber then just hold on for some stupid high speeds lol
  • 3 years later...
*EDIT*
for those interested, this motor took a turn for the worse after not even 3 track days, at calder i broke the oil pump when i went to clutch 4th due to a very early gear change on my part...the force of the 3-plate clutch pushed the crank straight thru n1 oil pump ending my day
however we pulled the motor down realized it was a godsend, the bearings were very close to be needing to be replaced and the crank was unharmed so a full overhaul was decided
also to those interested that was expecting a full house list of components myself included, well a surprise was in place
internals:
STOCK crank
STOCK rods
STOCK toyota piston
head:
STOCK
cams:
still unknown duration and lift
injectors:
mazda rx7 550cc
headgasket:
tomei(assuming)
oil pump:
n1
we were so shocked at how such a basic modded motor could put out the power it has done
here's a list of upgrades that will be going in/around the motor
ARP head studs
ARP main studs
ARP conrod bolts
TOMEI 1.2mm head gasket
BOSCH injectors(most likely 1000cc)
REIMAX oil pump gears
LIMIT bigger sump with tomei baffle
LIMIT oil breathing system/can
LIMIT surge tank
044 x2
SPOOL head drain kit
TD06H-25G 10cm turbo
TURBOSMART PRO-gate
MICROTECH LT12 ECU
and since scrapping the track s13 the motor will now reside in my daily driven R32 sedan
Edited by UNDR8D MOTOWORX
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
    • Not required but appreciated. Super Coppermix Twin even the non-competition model feels like the pedal is noticeably heavier than stock which was pretty well judged IMO. I'll be swapping in the Nismo operating cylinder soon to see how that feels.  Personally I haven't felt anything that justifies replacing the damping loop, at least compared to more modern stuff where the clutch delay valve is actually quite noticeable.
