Hi All Just a quick question about cam timing.When i got the motor rebuilt the Exhaust cam was 2 teeth out in Advance, This caused the turbo to boost alot earlier on but caused missfire up at top end. I have a rb25det with ATR43G3 installed. I noticed once i reinstalled the timing back to normal Turbo has lost alot of response. I have read in alot of previous comments about cam gears and saw somewhere that the intake\exhaust cam gear advanced\retarded XX Degrees help bring on power earlier but didnt increase top end. Just wondering if anyone could shed some light on this. Yes i know i will need a re tune but any comments would be greatly appreciated.
https://www.sau.com.au/forums/topic/401771-exhaust-cam-timing-rb25det/
Thanks for that . I corrected the timing my self when i replaced the head gasket and made sure everything lined up and triple checked before i turned the key. As i said car did give me a lot more lag. I did read somewhere about the adjustable cam gear and them bringing boost on earlier but it was some time ago.
I know there's no real difference with adjustable intake cam gears even if they preserve vct, but whats the general concensus on exhaust cam gears for rb25dets? Do they produce any worthwhile gains over the standard cam gear?
Edited by Mitcho_7
They shift the power band downwards - there may be a small drop at max revs but more power in the mid range - I can't remember the number but its worth the effort.
I think your move moving the band upwards, if your retarding it your delaying the closing of the exhaust valve so this is not going to improve anything but mid and top end power, you allowing the engine to breath when the revs are higher,
When your advance it your closing the exhaust valve earlier so more efficient responsive on bottem and some mid but not efficient at the top end cause the motor cant breath as well
My tuner said the cam gears see most gains on engines without cams, if you have cams they dont produce as good a gains, and you will loose bottem end to give to top end, i dont have cam gears and my idle is as lumpy as a wrx,
My RB25DET had 2 cams both stock. I think adjustable cam wheels are not that useful on aftermarket cams such as poncams or special grinds because they are presumably tailored to suit. I have no experience with RB26 but apparently they benefit from tuning adjustable cam gears.
And Sliver/Silver S2 I might have got it the wrong way round (I don't think so) but I can assure you the benefit was to the midrange not the max power. Don't forget that by retarding you are also delaying the opening of the exhaust valve.
haha, silverS2 it was supposed to be, your right it delays the opening so the exhaust valve , but i dont think its shifting power downwards, more like it increasing the filling of the cylinders and there efficiency at higher rpm ( more than 3000rpm) until they reach a restriction in the system, the drop at the top end your talking about is probably the turbo and exhaust manifold and system that start building backpressure which then becomes a traffic jam and decreasing or flatlining the top end, thats with a stock/small turbo, with my dyno graph you can see there is no loss or flatlining upto, its just keep climbing cause theres no restrictions.
advancing the cam would make the combustion more efficient by decreasing the overlap,
After a bit of research it seems 4 degrees retarded would be the way to go for the exhaust cam on a rb25det
I think that's right but ideally you would be doing it during a tune so you could see the effect on the dyno.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
