Another Trackschool day has been booked at Wakefield.
Date:
Thursday 21st JUNE 2012
Venue:
Wakefield Park, 10 km south of Goulburn, is a purpose-built closed road track environment which simulates typical driving corners.
Price:
Retail is $265 per person
Forum Special is $250. You need to mention this when booking.
THERE IS A BOOKING FORM ON http://www.trackschool.com.au
Track:
2.2km racing circuit.
Vehicle:
Use your own vehicle or enquire about trying one of our Type R Vtec Honda Integras with full roll cage, race seats, harnesses, coil over suspension, GTR brakes and R compound tyres (extra charge applies).
Track amenities:
Ample car parking, canteen, coffee shop, carports, lock-up pit lane garaging, tower and corporate area.
Price includes:
*15 minute sessions
*Lunch in raceway cafe/canteen
*Experienced race drivers/instructors including John Boston, Ian Dyk, Dean Evans and David Sieders. (Instructors may vary on the day)
*Theory sessions are held throughout the day for those who want it
Group organisation:
We only allow a maximum of 3 groups of cars for the whole day, with a maximum of 12 cars in each group.
Drivers will be divided into groups according to speed and/or experience.
Clothing requirements:
Please wear closed in shoes, socks, long pants and long sleeve shirt.
Bring a helmet (helmet hire is available).
Do you get a specific amount of sessions with an instructor? Any formality to ensure instructors are evenly shared amongst participants?
Since there's 12 cars/session and 4 instructors you'd average an instructor once every 3 sessions, so you should get two instructed sessions per day but it would be easy enough to miss out if its not structured.
50 bucks for a licence on the day that will set you up for the year, i know most people have their own timing and i even bought a gps thing recently but its a bit unreliable and its nice to have some kind of running score sheet on the day.
i know it sounds lame but thats a deal breaker for me
any licence's required or can we just rock up and go ?
Everybody is different with the instruction. It is extremely hard to work it out in a mathematical way on the day. Some people ask for multiple sessions, some cars do not have passenger seats, some cars arrive late or leave early. How many sessions would you like Adam?
You will need at least a Wakefield license LAMBCHOPS, as Patty has said. To get on to any track, generally a AASA or CAMS LS2 license is required. You can't just rock up, sorry. There is a booking form on the original post. I run these days every month at Wakefield and need to have people as organised as possible before they rock up to the day.
haha Patty...it does sound a bit lame ;)
Hehe it's not lame, I'm just a cheap bastard who wants all the trimmings for his hard earned.
The instructional coaching element is Arguably offering value much beyond what a standard track day could offer which for noobs is great but, well, basically I know Wakefield like the back of my hand and NO amount of teaching or practice could make me any faster than I already am on that circuit!
:ph34r:
:ph34r:
I bet these guys could point out a few areas you're making mistakes in...
And as you circulate through different trainers, they will pick up different things.
yeah Matt i was being a smartarse with that post, dont worry.
Im pretty sure i could spend the next 40 years on that track and still find ways i could improve my times, im just kinda shithouse at applying verbal instruction to my driving.
practice makes perfect i say, at least once you have the basics down.
If you are practising mediocrity, you will only end up with one result, being mediocre :action-smiley-069:
It should be perfect practise makes perfect.
That is the problem, most people do not realise the mistakes they are making.
haha fair enough, would like to think that if i noticed my times werent improving i would experiment with different lines, braking distances, vary which gear im in depending on corner until i noticed a drop in times again.
Unfortunately i cant afford to get out there often enough to have been able to 'perfectly practice' with my current set up. The last time i was out there i managed a 1.10.3 as a PB so im hoping with a little more effort that the car is capable of cracking 1.09's..
I am very curious to see what a pro driver could do with it, if i can get the GPS timer thing working then im tempted to sign up for one of these days just to see what the BOZMAN can show me is possible..
(lost the product key that enables the software and eric isnt replying to my PM's)
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
