slippylotion Posted June 7, 2012 Share Posted June 7, 2012 Inducer and exducer would be good. Link to comment https://www.sau.com.au/forums/topic/401832-rebuild-or-replace-m35-turbo/page/3/#findComment-6388865 Share on other sites More sharing options...
scotty nm35 Posted June 7, 2012 Share Posted June 7, 2012 From left to right: 46.6mm - 60mm 51mm - 42mm Link to comment https://www.sau.com.au/forums/topic/401832-rebuild-or-replace-m35-turbo/page/3/#findComment-6388984 Share on other sites More sharing options...
slippylotion Posted June 7, 2012 Share Posted June 7, 2012 (edited) Nice work Scotty. Thanks. So for a near stock replacement size a GTSS or GT2530 wheels would be quite good. Edited June 7, 2012 by slippylotion Link to comment https://www.sau.com.au/forums/topic/401832-rebuild-or-replace-m35-turbo/page/3/#findComment-6388999 Share on other sites More sharing options...
Sage222 Posted June 9, 2012 Share Posted June 9, 2012 my 03 just clicked over 100,000ks.. (gulp) Link to comment https://www.sau.com.au/forums/topic/401832-rebuild-or-replace-m35-turbo/page/3/#findComment-6391339 Share on other sites More sharing options...
sky^rkt Posted June 9, 2012 Share Posted June 9, 2012 mine lasted to 118,000kms so i guess i was luky Link to comment https://www.sau.com.au/forums/topic/401832-rebuild-or-replace-m35-turbo/page/3/#findComment-6391501 Share on other sites More sharing options...
Reprieve Posted June 9, 2012 Share Posted June 9, 2012 03. 150 000kms stock turbo still going strong lol Link to comment https://www.sau.com.au/forums/topic/401832-rebuild-or-replace-m35-turbo/page/3/#findComment-6391652 Share on other sites More sharing options...
Jetwreck Posted June 9, 2012 Share Posted June 9, 2012 Got 112 out of mine......from memory I think kngm35(Damo) had 157 before his died! Link to comment https://www.sau.com.au/forums/topic/401832-rebuild-or-replace-m35-turbo/page/3/#findComment-6392037 Share on other sites More sharing options...
PN-Mad Posted June 9, 2012 Share Posted June 9, 2012 Plus whatever all the cars had on them in japan, prior to be given the haircut... Link to comment https://www.sau.com.au/forums/topic/401832-rebuild-or-replace-m35-turbo/page/3/#findComment-6392041 Share on other sites More sharing options...
Philmeup_s13 Posted September 26, 2012 Share Posted September 26, 2012 What sort of noise does an M35 turbo usually make when its on the way out? I have always heard turbo failure as a whine, but mine and just started making a clicking/scratching noise under low boost/when i take off, but rectifying itself higher in the revs or in 3rd+ gear. Is this actually the turbo on the way out? The Odo says its only done 66k, seems a litte early really... Link to comment https://www.sau.com.au/forums/topic/401832-rebuild-or-replace-m35-turbo/page/3/#findComment-6552701 Share on other sites More sharing options...
ironpaw Posted September 27, 2012 Share Posted September 27, 2012 (edited) What sort of noise does an M35 turbo usually make when its on the way out? I have always heard turbo failure as a whine, but mine and just started making a clicking/scratching noise under low boost/when i take off, but rectifying itself higher in the revs or in 3rd+ gear. Is this actually the turbo on the way out? The Odo says its only done 66k, seems a litte early really... try adding 50-100k to that figure for the real mileage... Edited September 27, 2012 by ironpaw Link to comment https://www.sau.com.au/forums/topic/401832-rebuild-or-replace-m35-turbo/page/3/#findComment-6552772 Share on other sites More sharing options...
Daleo Posted September 27, 2012 Share Posted September 27, 2012 What sort of noise does an M35 turbo usually make when its on the way out? I have always heard turbo failure as a whine, but mine and just started making a clicking/scratching noise under low boost/when i take off, but rectifying itself higher in the revs or in 3rd+ gear. Is this actually the turbo on the way out? The Odo says its only done 66k, seems a litte early really... That's pretty much the way they sound; mine made some very odd noises for a while (sounded like the BOV was leaking, then sealing) before it became extremely noisy, but still made boost (dropped a blade tip) then failed completely (dropped the rest of the blades) about 500km later. You might want to start exploring your rebuild options before it fails completely. try adding 50-100k to that figure for the real mileage... Mine lasted until 105,000km but I'm pretty sure it had around 20-30,000km more in reality. There is no ironclad guarantee that the number on the odo, is the actual reading. Link to comment https://www.sau.com.au/forums/topic/401832-rebuild-or-replace-m35-turbo/page/3/#findComment-6552895 Share on other sites More sharing options...
Philmeup_s13 Posted September 27, 2012 Share Posted September 27, 2012 Cheers guys, as i bought from a dealer I may be able to get something under statutory warranty (only bought the car 4 weeks ago). Completely understand about the ks thing, I have owned jap imports for years (s1 stag, silvia, cefiro) and they have all had "low ks" when they clearly have been wound back, but judging by the condition of this one there no way its done 150k plus, even if it had been wound back 30k, I wouldnt expect a bog stock car with under 100k on the clock to have turbo failure...shame on nissan ift his is a regular occurance. Link to comment https://www.sau.com.au/forums/topic/401832-rebuild-or-replace-m35-turbo/page/3/#findComment-6553032 Share on other sites More sharing options...
PN-Mad Posted September 27, 2012 Share Posted September 27, 2012 Ha... yeah, happens all the time. Not always the kms, but blockages in the oil feed line don't help the matter and starve the turbo of oil. Its the sort of thing you should budget for when buying the car really. It was a bad design, and very restricted. So plan would be - Scotty dump pipe, turbo rebuild with smallest highflow- whatever Dale got seems to be on the money. That will make it happy. Link to comment https://www.sau.com.au/forums/topic/401832-rebuild-or-replace-m35-turbo/page/3/#findComment-6553068 Share on other sites More sharing options...
scotty nm35 Posted September 27, 2012 Share Posted September 27, 2012 Lack of servicing is the cause, along with high stock boost levels. Link to comment https://www.sau.com.au/forums/topic/401832-rebuild-or-replace-m35-turbo/page/3/#findComment-6553092 Share on other sites More sharing options...
ironpaw Posted September 27, 2012 Share Posted September 27, 2012 What about this HKS GTRS that fits the M35? Is that what Craig has? Link to comment https://www.sau.com.au/forums/topic/401832-rebuild-or-replace-m35-turbo/page/3/#findComment-6553104 Share on other sites More sharing options...
PN-Mad Posted September 27, 2012 Share Posted September 27, 2012 Nah, Craig has a 3071 high flow. GTRS needs custom shit done to fit. Link to comment https://www.sau.com.au/forums/topic/401832-rebuild-or-replace-m35-turbo/page/3/#findComment-6553117 Share on other sites More sharing options...
