hi im currently selling my beloved1996 series 2 r33 gtr. The reason im selling this car is that im getting married soon and unfortunatly i need it gone.
This car is immaculate inside and out, and never missed a beat. It has 104500 genuine ks with geuine japanese log books to prove. it has had a major service reciently. The car is pretty much stock except 4 the following.
-kakimoto cat back exhaust
-tien springs and shocks
-iridium plugs
-turbo timer
-nismo 320k dash
-kenwood cd player
-twin hks pod filters
-aftermarket custom front pipes
-hi flow cat
-federal 595 275/40/17
there is not one thing wrong with car and is a perfect example of wat a gtr should be like, it also has a few rare fatcory options like the rear pods and the lip on the bonnet...im asking 4 $21000 but that is neg. im located in sydney and for and thing else u can call me on 0423551301
https://www.sau.com.au/forums/topic/401857-skyline-gtr-r33-1996-v-spec-sydney/
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
