hi im currently selling my beloved1996 series 2 r33 gtr. The reason im selling this car is that im getting married soon and unfortunatly i need it gone.
This car is immaculate inside and out, and never missed a beat. It has 104500 genuine ks with geuine japanese log books to prove. it has had a major service reciently. The car is pretty much stock except 4 the following.
-kakimoto cat back exhaust
-tien springs and shocks
-iridium plugs
-turbo timer
-nismo 320k dash
-kenwood cd player
-twin hks pod filters
-aftermarket custom front pipes
-hi flow cat
-federal 595 275/40/17
there is not one thing wrong with car and is a perfect example of wat a gtr should be like, it also has a few rare fatcory options like the rear pods and the lip on the bonnet...im asking 4 $19000 but that is neg. im located in sydney and for and thing else u can call me on 0423551301
https://www.sau.com.au/forums/topic/401858-gtr-r33-skyline-1996-v-spec-sydney/
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
