hi im currently selling my beloved1996 series 2 r33 gtr. The reason im selling this car is that im getting married soon and unfortunatly i need it gone.
This car is immaculate inside and out, and never missed a beat. It has 104500 genuine ks with geuine japanese log books to prove. it has had a major service reciently. The car is pretty much stock except 4 the following.
-kakimoto cat back exhaust
-tien springs and shocks
-iridium plugs
-turbo timer
-nismo 320k dash
-kenwood cd player
-twin hks pod filters
-aftermarket custom front pipes
-hi flow cat
-federal 595 275/40/17
there is not one thing wrong with car and is a perfect example of wat a gtr should be like, it also has a few rare fatcory options like the rear pods and the lip on the bonnet...im asking 4 $19000 but that is neg. im located in sydney and for and thing else u can call me on 0423551301
https://www.sau.com.au/forums/topic/401858-gtr-r33-skyline-1996-v-spec-sydney/
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
