  • Replies 91
Scored this hi-flowed RB25 turbo for the rb20det
Its a strange one tho, its not like the other one i have, the core and rear housing are one casting still, but its not a standard rb25 core..
Started moding the manifold today to for the external wastegte
Haha
Just a short skiny screamer for some serious noise is what it needs i think.
The laurels gota be up to cert and warrent standard,so ill have to make a plumb in setup for the screamer aswel.
Edited by NZDRIFTER
  • 4 weeks later...
Some quick vids of how she sounds with the new exhuast, still needs a tune, iv had a bit of fuel pulled out and the tps map from jonos s13 (the white one from stadium drift tuned by mercury) put in but thats it, still runs pretty rough.
  • 3 months later...
Time for some updates, iv been super slack lately so I will try an redeem myself.
Dyno time.
First run just running waste gate spring pressure (8psi) and boost creeping to about 11psi it made 266kw (356hp) at the wheels. Next will be tuning with the boost solenoid wired in and running around 14psi.
Edited by NZDRIFTER
On 13psi we had 252kw at the wheels but the injectors were at 100% duty cycle so it was droped back to 10psi and this is what I left with :thumbsup:
She still pulls nice and hard on the street, ill be going back with some bigger injectors and modified manifold sometime soon.
Boost creeps from poor manifold design..
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
