4 Door Fever ~ Rb26 R32
  • Replies 91
The R34 also got some love this week, Nistune installed and tuned :D
This is Torque & AFR from the standard tune with pod filter and exhaust
This was with adding the front mount intercooler and a few quick chnges to the tune
A bit more tuning
And this is where we finished up on 10psi boost, the difference is amazing it pulls much harder now.
Edited by NZDRIFTER
  • 2 months later...
Silver mate,
The last few months iv just been taking the car out for a few late night missions and drives out in the country.
For not having a wheel alignment the thing drove pretty damn well, but I have recently fitted some Partshop max solid rear subframe bushes and got it a decent wheel alignment
Now the first problem, something had to happen eventualy..
The gearbox is in desperate need of some new bearings.
Im planning on taking it to powercruise at Taupo motosport park in November, so im borrowing a gearbox of a mate and spending the next montho or so getting the car 100% ready for the track.
Helped assembly a friends RB27dett on the weekend.
  • 2 months later...
Finally took the R32 to an event, PowerCruise #45 at Taupo motorsport park.
I had a Great time and cant wait to for the next one with more power!
This is a video from first thing in the morning I have a better one ill upload to.
My mates RB27 and LS1 v8 Cefiro's
My mate nicks GTR with full HKS T04z kit
  • 1 year later...
Alrite its been a while.... a long while... so ill try make this atleast a half decent post.
So far the R32 has survived another event so ill share that with everyone, a totally awesome day out drifting with the Zokusha Worx crew
Well the morning didn't start so great, just driving the car to line up the engine didn't feel or sound right.
Out on the track it was cutting out, feeling underpowerd and pretty much just driving me crazy.
I spent most of the morning trying to fix it tighting up everything checking every sensor and connection, in the end it seems it was the main ECU connector that needed a slight tweak and by about 11:30 it was all go and I could start getting some decent drifting in.
The track was Taupo Track 3 the back section of Taupo Motorsport park.
So since trackday i have purchased and fitted some 750cc injectors removing the standard items, i have also opend up the wastegate ports inside the exhaust manifold to fix the boost creep problem, the goal is 300kw (402hp)
A few things out of shape after trackday..
Removed the exhaust manifold & gave it to a mate to open up the w/g ports
Also purchased a new vehicle with a little more grunt than the hilux to tow the skyline.
4.2 Diesel manual 116,000kms
Also an update on the old mans R34, i spent a bit of time making a new trubo setup for this and it all worked out pretty well.
started off with 1 new exhaust manifold from Sinco Customs
A Turbonetics Turbo and tial 44mm wastegate
And got to work
gAnZJzN.jpg?1
And with Mike from Diesel & turbocharger services tuning the nistune ecu we stopped at 14psi with it droping off to 11psi until I sorted the boost issue, now with a flatish 14~15psi we have 260kw at the wheels with the Revs shooting up from 3500rpm.
 Share
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stop on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, you need to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
