  • 5 weeks later...
  • Replies 91
So after installing the boost controller it was time to test it out on the dyno.
sorry the pics are a bit shity but here we go.
We tryed 3 diferent settings,(stock turbo is f**ked) 7psi,9psi and 10.5psi droping off to around 9 leaving it at 170kw.
Sadly it was pig rich,stupid stock ecu, so theres an easy 10-15kwto be had if it was runing around 12.5:1
but ended up with a 14% gain overall.
KW and Torque
KW and boost
Torque and boost
Since we have turned the boost up on the R34 it was time for a front mount intercooler
I was pretty surprised how much bigger the GTT intercooler is compared to an R33 one
Delta fin 8-) tested on of these coolers on my mates rb25 s13 on the dyno against another type of intercooler and it really performed well,
much lower intake temps.
will probly finish it on tuesday
Hmmm i started having a problem with the r32 idleing really high, and it seemed like the throttlebody's were not fully closing.
After checking everything that could be affecting the last thing to do was remove the intake manifold,and im glad i did....
Pulling the plenum away from the throttle bodys i strait away saw the peice of tissue paper caught around one of the throttlebodys,dope au
So i thought f**k while this shits off i might aswell do as much as i can so i decided to get rid of evrey single water line, heater hoses and all,everythings gone, getting rid of some realy shit hoses andd a million possible leak points
And i also gave the plenum a blasting while its off to
As soon as i get some ball joints and swaybar bushes this will be going in the laurel
Thanks DJRIFT, yea its definantly a problem, my tuner had a considerable voltage drop in his 32 GTR through shitty old loom,
So he wasnt going to tune mine until i had done it haha.
:thumbsup: Cheer's Samos69, haha yea well my mate had a GTS-t the same year and the rego just said "skyline coupe" so we threw the rego and plates on
the GTR, i drove it all the way from Auckland to New plymouth :sweat: 260km runs on the motorway
Trying to build a responsive 20 :P
Its a Garrett copy T28, watercooled, 360* thrust bearing and .64 rear, should be good for the rb20, even a shity t3t4 makes 20's pretty damn laggy, so this shud be good.
Yea its a t3-t2 adaptor and im going to have the wastegate venting from it, much easier than moding the manifold, and it means i get
to keep the heat sheild ;)
I saw a picture of a cef a little while ago with one, and that was runing a huge turbo to, so im hoping it will fit fine in the laurel (finger's crossed)
Just palnning on runing it on around 13-14psi runing a mines chiped ecu, would be happy if it made 160-170kw,injectors would be maxed tho.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
