well its snowing heavily here in the south island Nz today, so on my way home i push the button SNOW and the car went from 2wd to 4wd.
It works brilliantly it starts in 2nd gear and i think its 40/60 split torque. Also the heater under the windscreen works a treat, no snow build-ups. ;)
https://www.sau.com.au/forums/topic/401890-snow/
Thats something not many of us are able to try out!
I think its a 50/50 split, and the other thing I notice is that the Throttle map is heavily reduced, giving you that sluggish feeling. I guess gearbox pressures are reduced too.
I only use it to get the car up onto ramps easily!
https://www.sau.com.au/forums/topic/401890-snow/#findComment-6386472
Yep, snow mode is fantastic - does exactly what its meant to! I took mine from Adelaide to Falls Creek 2 years ago now I guess and the car was absolutely brilliant, didnt miss a beat. Defrosting the windows and mirrors was also a nice added bonus of my cold weather pack :D
https://www.sau.com.au/forums/topic/401890-snow/#findComment-6386489
i don't have a torque meter or anything to find out so what happens when i press the snow button in my manual converted rs4?? does it just do the torque and forget about using 2nd? or does taking out the auto box mean i am just turning on the light in the dash when i push the button??
https://www.sau.com.au/forums/topic/401890-snow/#findComment-6390021
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
