I'm having the induction noise issue to, only noticed it when i use my headset though, being the TV speakers dont have that detail of sound. The exact same thing happens, only works properly with the supra. On the stereo topic, i just turn mine off so i can hear the goodness of a twin turboed V12 :yes:
Ok good.
So it's not just me.
  • Replies 199
They could have at least given us the farken S13 Silvia instead of ka24de pos.
Also noticed It seems like it's geared more towards LHD in general, which kinda sucks cus usually I drive from in car view and it does my head in when driving LHD so I keep needing to change camera.
They should make a JDM drift pack with the real performers of Japan.
Its about time we saw some of japans sedans in games:
- R32 Skyline 4door
- R33 Skyline 4door
- R34 Skyline 4door (not in blitz trim)
- C33 - C35 Laurel (only ever released in Tokyo Extreme racer series)
- A31 Cefiro (only ever released in Tokyo Extreme racer series)
- JZX 81-110
I for one don't find a mini or a fiat 500r bambino (abarth) an interesting addition to a game designed to break every road rule on the planet.
Just saying....
GT40 gear lever is on the wrong side.
I am annoy.
The Abarth 595 is fun with full race everything, until you realise it can only do 140kmh and you can't change the gearing to make it go faster because THERE'S NO f**kING TUNING!!!
Abarth with about 300kw is awesome fun.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
