  • Replies 199
Anyone else notice the Sierra RS500 is listed as a US car even though it's right hand drive?
There was another thing I noticed, not car related but game related even though its a small thing, rear vision mirror does not pick up any signs or a-frame banners. was try to reverse into a discount sign one after missing it.
^no smoke show's up in the mirrors either, though that's probably more of a frame rate/performance issue
It's already on iOS, I'd imagine it's only a matter of time.
Forza Horizon needs a second hand car dealer. Given the different focus of the game it'd be pretty cool to pick up someone elses half modded car and have a bash.
Here's hoping they update it to allow tuning soon. Giving me the shits. No point in extra aero, racing trans or 2 way diffs. Even suspension is probably pointless.
Also wondering why we can't buy off road tyres? If we stump up for race tyres are we running around on dirt roads in slicks?
Yeah I made an AE86 with a 2jz fully modded for shits and giggles, the thing is completely undriveable. Even 6th gear at 300km/h it just spins up the tyres as if it's in 2nd heh.
Longer gear ratios would be nice!
Lol i just made an original GT-R with R35 V6 for the same reason, although its almost drivable.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
