I'm having the induction noise issue to, only noticed it when i use my headset though, being the TV speakers dont have that detail of sound. The exact same thing happens, only works properly with the supra. On the stereo topic, i just turn mine off so i can hear the goodness of a twin turboed V12 :yes:
Ok good.
So it's not just me.
  • Replies 199
They could have at least given us the farken S13 Silvia instead of ka24de pos.
Also noticed It seems like it's geared more towards LHD in general, which kinda sucks cus usually I drive from in car view and it does my head in when driving LHD so I keep needing to change camera.
They should make a JDM drift pack with the real performers of Japan.
Its about time we saw some of japans sedans in games:
- R32 Skyline 4door
- R33 Skyline 4door
- R34 Skyline 4door (not in blitz trim)
- C33 - C35 Laurel (only ever released in Tokyo Extreme racer series)
- A31 Cefiro (only ever released in Tokyo Extreme racer series)
- JZX 81-110
I for one don't find a mini or a fiat 500r bambino (abarth) an interesting addition to a game designed to break every road rule on the planet.
Just saying....
GT40 gear lever is on the wrong side.
I am annoy.
The Abarth 595 is fun with full race everything, until you realise it can only do 140kmh and you can't change the gearing to make it go faster because THERE'S NO f**kING TUNING!!!
Abarth with about 300kw is awesome fun.
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
