  • Replies 247
Guys, I know it's a long shot but as posted in FB, anyone got a speed flow black -6 tool so I can fix my drama? I can still do skids without it but the AFRs are shit below half tank as I think the pickup hose and filter is stuck after messing around yesterday?
If you can't get a -6 wrench you should be able to use any adjustable wrench
Yeah didn't want to mark the fittings, however you just sparked an idea.... If I don't get it done tonight I'll get it done while im there....
oh, you poor thing.....
use an old tyre tube between shifter and fitting.
should work.
id say thered be a few, but yeah i got my 1400kg jack,
gotta jack one side at a time but come hit me up to use it, ill be in a red hoody and black jeans if you dont remember me from putty road cruise >.<!
thanks man.
sorry, my memory is up to shite.
will remeet you tomorrow.
Manuel, I told you, call in sick.
they have to have someone to cover the shift.
what would happen if an emergency happened?
THIS IS AN EMERGENCY!
sounds good mate.
goodnight everyone, waking up at 4 tomorrow woo.
Bringing the second jack, we can do this shit NASCAR style!!!
Fking 4 am :( so not looking forward to that part, I'll hate you all until I wake up properly... Night :P
Being im only in doonside might sleep in till about 630am and still be there by 7. Only takes 10 min drive for me lol. Car is prepped and ready, helmet dusted all ready to go. Goodnight see u all soon!
    • *that* is a question for chatgpt (or someone that understands maths....but I'd try chatty). Drop them the table and ask for the formula
    • Alright. Exhaust has been looked at, and booked in 'soon'. I'm not 100% convinced it's going to be as good as possible but I'm going to go with it anyway. If I get a reasonable thing that works for 10 years I mean that's twice as long as I've lived with the current one. I have a more pressing issue. I have fixed my MPVI3 (by buying a new one). Excellently, one can wire in analog 0-5v inputs to the ECU itself. I had wideband already via Serial so I also wired it in via the direct input. The idea being I can use the standalone logging without a laptop and have Wideband data in it. The other wire I thought I'd use oil temp. This is where I've gone crazy. HPTuners requires you to implement a formula so you know how much volts = how much temp. This seems relatively simple to me. However I cannot find the scale for this anywhere on the internet, nor decipher how to figure it out without removing the sensor from the car. All I know is that voltage actually goes up as temperature goes down. I am using the actual gauge, so I can see what the temp is. The signal wire has been branched off into the MPVI3. EXAMPLE: 2.68v = 58C 2.7 = 57C 2.74v = 56C 2.8V = 54C 3.06V = 49C 3.18V = 47C 3.37V = 43C I think the gauge is 50-150C. It may be more. It may be less, because I can't find it for the love of f**k. It appears all the information about the gauges I have has been scoured from the internet, but the sender is VDO 320.021 I believe the resistance chart is this How the f**k do I convert this to a voltage? Once I have a voltage... I then have to perform this transform of said voltage to show it in the scanner: https://www.hptuners.com/help/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm @GTSBoy you're probably my only hope here TEST YOUR MIGHT
    • Here’s the updated and installed muse replica nismo ones … very happy with the outcome. Eventhough I painted my whole rear end due to my rich idle lol.
    • Hmm. I had a good look (w/o searching, because I'm not logging in) and couldn't see it either. I distinctly recall the thread, not many weeks ago. It must have been removed or perhaps put into the back section. If it was in Off Topic you should at least have been able to search it up. So if I'm not hallucinating, it is fairly decently removed.
