A few weeks ago I tried setting my base timing to 15deg advance
I lined the markers on the third white line after the orange(or red) line.
Is this correct?
at this time the CAS bolts was pretty much at the centre of its bracket
but for one reason or another my CAS died and now I have replaced it with another one sourced from a RB25DE
The thing is, with the new CAS, when I line up the bolts in the centre, the timing is way off. I adjusted it fully clockwise and I only manage to line up the markers with the 4th white line after the first orange one.
All this time I used the same kind of timing light, so Im pretty sure its not the light. Is it possible that the CAS from the two engines give different readings?
https://www.sau.com.au/forums/topic/40194-setting-base-timing-problem/
