Hi guys.
I'm looking to buy some Dzus fasteners to fix panels, under trays and diffusers etc to my car for quick removal.
Can anyone recommend where to buy from? Seem expensive in some places. Tried eBay too. but unclear on how they attach to the fixed part.
I want the self ejecting type on this website.
http://www.performancewholesale.com.au/component/content/article/305-dzus-part-numbers?catid=57#selfeject
I'm a bit unclear on how they attach to the fixed part. Any advice or guidance.
thanks
Russ
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/
these things can be a bit of a pain, especially for things which are on and off regularly. They can get sloppy and misaligned.
There are other types of clips, or even consider bonnet pins for ease of use
I completely agree......
If you're looking at these for undertrays or flat floor sections I'd consider again Russ.
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/#findComment-6387914
These are awesome for certain things, such as bodywork etc that comes on and off fairly often. Definitely wouldn't use them on parts that are excessively heavy or may take a hit, like a floor or undertray though.
Major negative in my opinion is that they aren't very tolerant of misalignment. If you want them to much locating of the part, there are better options.
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/#findComment-6392660
  • 4 weeks later...
All of the turbine helicopters use these for most of the exterior panels that aren't structural. You can buy the in some fairly large sizes and I haven't ever seen any fail that haven't been miss installed (wrong length or old/over tightened and broke the tangs).
If it has to take load I'd run nut plates and countersunk screws with a reinforced section in the removable panel. Might take 20 seconds longer for 6-10 screws to remove but for piece of mind. Buy an electric screwdriver and its the same time.
Also note that nutplates are way stronger than rivnuts without the issues as there steel not aluminium.
A few places on the airport sell dzus fittings in different sizes and styles.
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/#findComment-6431335
Could try Camlocks too, often used in aviation where the breeze would be something approaching LMP speed on the Mulsanne.
Pretty much all methods mentioned, require reasonably accurate hole location.....although you can get floating nut plates that give extra wiggle room. Wicks and Aircraft Spruce - among others, do have handy little duplicating devices and templates which can save a bit of potty mouth during the fabrication.
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/#findComment-6433880
  • 1 month later...
Dzus Fasteners? I work with them everyday. they are okay when new but after a bit of use.... they are designed to save time and to make sure stuff isnt overtorqued but after a bit of use they are just dumb. usually-well mannered people start using swear words and even invent some, and to be honest, they are pricey. Use the money on a good snap-on electric screwdriver, get some anchor nuts (nylock type) and forget these stupid things.
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/#findComment-6505819
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
