  • 4 weeks later...
  • Replies 77
Quick question regarding mounting the digital sensors...
Do they need to be mounted in the exact centre of the car - or at least in the exact same spot as the original sensor?
Also curious about this.
anyone else had experiences with these units?
  • 2 months later...
  • 1 month later...
  • 4 months later...
You will have to do some research for current info
I understand both brands do a standard and a higher tweaked unit. (they are likely the same unit/technology if you see pictures of both side by side, maybe a different colour casing)
Also look at the capabilities of the ETS Pro? before rushing out and buying a unit.
Yep I'd hold off.
I bought the Midori one and - though it's been back to Midori for testing - found it to at least be reporting a fake signal to my V-Spec's digital G display.
Nissan G-Sensor:
http://youtu.be/Ct5od-3hSXA
Midori Spec Digital G Sensor
http://youtu.be/RHpTvkDVq8s
Although they aren't driven the same route - you can see that with the Midori unit in place the G display is shunted to the left whenever the vehicle is in motion.
I'd love some advice on this issue if anyone has any!
  • 1 month later...
What you see is how they work. I make the Skylab Fusion digital torque split controllers in the UK.
All these units so is tweek the voltage coming out of the G Sensor. Well, thats a simplified version.
What you see on the screen related directly to the voltage output from the G sensor. When the dot is in the middle, the G sensor is outputting 2.5 volts. 1.2G is 0.5 or 4.5v depending on direction. The usual ratio is linear. What my controller does , and all the others is alter the relationship between actual G and what the ATTESA sees.
This is why you cannot use them accurately with the R34 Display.
Just doing a price round up as I previously mentioned my attessa unit is busted and I need a new one:
Tarzan G Box - $ 648.65 - http://www.nengun.com/do-luck/tarzan-g-box
Midori Digital - $ 560.48 - http://www.nengun.com/midori-seibi/midori-spec-digital-g-sensor
ETS Pro - $599 - http://www.full-race.com/store/r14-awd-skyline/ets-pro-center-diff-torque-split-controller-for-r32-r33-r34-skyline-gt-r-1.html
Am I missing any? Haven't found any more info on Ruzic's G Sensor replacement. Is there any difference between these three?
These are all 100% OEM replacements?
Skylab Fusion $420
[url=http://www.gtr.co.uk/forum/175702-skylab-fusion-e-ts-controller.html[/url]
Firstly - THANK YOU.
You've been the only person (including Midori Seibi) whose been able to answer my question!
So, to confirm, the jump to the left is purely a miscommunication between the G-Sensor and the MFD, caused by an increase in voltage by the Digital Sensor and not a fault.
If that's the case you've made this old man very happy and very relieved!
THANK YOU AGAIN!!!!!!
Yes, there is no error, its just the way it works. What you have experienced with Midori Seibi is an unwillingness to be co-operate with the seller. They know exactly what their controllers do and what their short comings are. All controllers that work this way will have this effect. What you can do it leave the original G-Sensor wired just to the MFD. That way the G you see is accurate and the controller can still work.
  • 1 year later...
A quick update to this thread, I ended up getting a Do-Luck DTMII and blew it up trying to wire in the throttle cable :cheers:
Now I'm the market again for a g sensor. Is there any new products on the market? The Skylab looks interesting, anyone got one?
Is it PnP?
Er huh?
Don't get it? I replaced my one with the Tarzan G-Sensor and the display is now working A-OK
No extra wiring needed...
Maybe it's an update but the new unit I have works fine with the display.
Out of interest, how did you wire it for it to fry itself?
Is it PnP?
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
