Eoi:- Private Drag Day At Adelaide 1/4 Mile. July 1St 2012
  • Replies 197
Posted Images
so i got some vids of a white r32,burgandy33 and a black 33 and munro and willal's 35 ( what happened marty ) if u want ill post some up if u dont want also say and i wont up load them to u tube
Munros 10 second daily...he has a habit of that.....
As for our car Jet looks to have an intermittent switch on one of the paddle shifters, so rather than wait two hours between runs twiddling our thumbs, we called it a day. Very low grip compared to last meeting, which means Munro will go faster :)
saw kiers last run, seemed to have trouble getting into 3rd??
good effort from munro, got a warning for 10.9? so ran a 10.7? good work.
as for whathisname, he need to be more aggresive with getting tyres warm. he will maybe update on times from him
Yep. Did what I was told. Steward said no more 10.9s...........10.7 sounds better anyway!
The Michelins are 500 compound so harder than the last Dunlops.
John, did they talk to you after your second 10sec run?
Usually only 2 runs then they kick you out isnt it.
what preasure were you running in those tyres? would less PSI give you quicker 60foot? also would suspension on softer be any advantage like the old drag days where softer was better?
Yes they came up after the 10.9 & said no more 10.9s......
Next 2 runs were 10.7s........
If I saw a steward coming towards me I ran away! haha
I dont think messing around with tyres pressures will make much difference.
If I wanted to go again it would need softer tyres & a lighter driver.
Im happy to leave it at that for now!
yep 10 second daily's are sweet
this bloke marc now has a definate 10 second daily taxi, bruce heinrich built and tuned 430 rwkw and 10.8 with a 132mph on nitto invo's 255/18's with a 1.7 60
winning for less than 10k if his last tuner didnt destroy his engine this could of been done off 5k in mods bang for buck 10's
and good to see the gt 35 having a go
Edited by JETURBO
After thinking I had hurt the botton end 'prior' to my first pass, I think I can be cut some slack for not getting aggressive in the burnout. Turns out the turbo is getting too much oil at sustained high rpm, doesn't happen on street or dyno, took a few runs to surface on strip. Comp test and leak down show engine is perfect.
In short, my times are rubbish. I didnt get one decent pass out of the three attempts. I took it easy on 1st pass, nailed it top of 2nd onwards: 12.5 @ 126+ (2.4 60ft) wheel spin. Second pass I tried a clutch slip launch, appeared to suffer clutch issues and got out of it in 3rd, got on it again three times, finally the last time it started accelerating again. The footage that evening confirmed wheel spin through 3rd, not clutch. Last pass, came off the line slow thinking I had to nurse the clutch, better burnout (decided if bottom end was on the way out I may as well do a good job) got reasonable grip through 3rd and ran a 12.2 @ 128.6 (2.48 60ft).
Engine is fine, clutch is fine, I now have a baseline with new set up. A soft 2.0 should see mid-high 11 @ 130+
Mate I will give some advice. Forget Drag racing with a RWD manual. Come out to Mallala & have a ball
with that car. You will not be able to wipe the smile off your face TRYING not to drift on a grip day!!!
Your R33 is one of the nicest cars in Adelaide. Absolute gem of a car - I LOVE it.
If you really want to drag it properly, get some proper slicks & let me show you how to do a proper burnout!!
haha. seriously, come to the next passenger track day at Mallala & stop stressing out about the drags.
I will take you for a ride in my R33 then you can follow me....I'll leave it in RWD promise..............
glad to hear nothing is wrong. take Munro's advise take it mallalla and have some fun. anyone can drive in a straight line, do some laps out there.
hey JETurbo thanks for posting that vid up. thats me in the V35.
it was my first time at the drags and i really enjoyed it, but i was a bit dissapointed with my best time of 14.28 (only did two runs, the first was a 14.92!)
i was expecting to go at least a second faster!
What mods?
How much power?
everyone does lol
good onya for having a crack
John, Matt, I set out with a goal of running as quick as possible on 17-18" rims and street radials and a few small mishaps won't stop me going back for more. I've got our JWM IPRA team to focus on when it comes to Mallala - see sig - but I like the sound of your offer, John. Count me in. Congrat's on running 10.7 @ 134. Thanks for the kind words re my car too.
Andrew, I'm planning on going again in Sept or Oct. Yeah traction issues were greater than expected.
Jet, if plates aren't obvious feel free to post YouTube clips of the Burgundy 33. Cheers.
ok ill up load it dont mind my mates in the background bagging the crap out of that white vt lol
ur car sounded like it was clutch slipping at half track and 3/4 track what was going on just the oil issue?
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
