  • Replies 56
I'm curious why Japanese cop cars need a screen to stop the sirens blowing off!
Siren actually appears to be located below drivers side headlight :D
As for the lights, i agree... surely by putting a shield there, they are compromising the aerodynamics of the car, which means that they cant go as fast as they would be able to if the screen wasn't there.
They should just bolt the lightbars to the roof/roof rack, like all the other Police forces across the world do!
oh... and how many light bars did they lose before they decided that this was a good idea?
I've seen these screens on some really old Japanese Police cars. (70's)
I think you've answered the question yourself there. Its probably done because its always been done for decades. Thats how a lot of stuff works in japan. So much bureaucracy that even obvious stuff is overlooked because a piece of paper says different. I would expect that the police body in Japan is one of the most bureaucratic institutions in the country, so change is very difficult(read impossible). You see a lot of stuff like this in Japan. Its always been done, why question it?
They're only compromising already compromised aerodynamics... (ie: having the lights on top).
Anyways, I believe having a flap there to direct wind over the lights actually helps rather than compromises.
I remember one guy who said that that flap thingy was there so that a head-up display could reflect back info to the driver of the cop car... :confused:
I've heard that too, but it just sounded plain wrong.
...i don't think they had head-up display technology in the '70s ;)
I'm happy with the wind deflector theory, and I'll stick with that one :P
to add a bit onto the gaijin explaination...
Jin is a suffix that means 'persons' or 'people', so Australians are literally 'Australia-jin', japanese are 'Nihonjin' (Nihon = Japan), english are Eigo-jin... add 'Gai' which (afaik) 'outside', and you have gaijin, meaning 'outside people'...
I'm doing japanese as a subject for my uni degree, which I'm doing externally at the uni I work for... I've always been facinated by the jap culture, and learning the language is a complete eye opener... sounds a bit fruity, but it's very rewarding... but I'm still learning, and some of it is challenging... Nihongo ga sukoshi hanashimasu. :)
I'm hoping to get an IT job in Japan, but I'm being realistic... from the stories of racism and hyper-compeditive job markets, it may be difficult.
Edit: Some more on the gaijin thing... you've got 'gaiteki' which translates to both 'outside' and 'foreign enemy'... so I guess you could say that (like a lot of stuff in japanese) it has several similar meanings... outsider, foreigner, alien, etc.
  • 4 months later...
I lived in Osaka in 2000 for a year and had heaps of fun drifting almost daily at Nanko and other little wharfs along the bay. Back then the cops just did the old drive past and then u wait till they go home. Returning to Osaka last year I was shocked to find many barriers and gates installed at my favourite haunts. Oviously the police are making a move on drift in the city. Of cource certain areas are still great but it may not be long before mountains are the normal drift site. Nanko minami is basically shut down now with the road barriers in place.
Police and governments may be changing their attitudes in Osaka.
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
    • Looked it up. It sounds so expensive lmao I'd rather not. Awwwww but I just love that sound
    • If you want the screaming "weeeee" sound, just let the gasket between the exhaust manifold and the turbo break a little. It'll go "weeeeeeeeeeeeeeeeeeeeeee" everytime its on boost...
