Hi guys I'm new to this forum,
Ok iv purchased an rb30 block, it's been deck,honed, blue printed, balanced ,
New stock rb30 rods, race bearings, acl dura light pistons ra9301y 1.00 rib 0.025
Iv got a rb25det neo head that I plan on using for the build, I'm wondering what head gasket
I should use? Any info would be great please.
I've looked (for the past 10 minutes lol) for the pistons you state above. I cannot find them.
http://www.acl.com.a...80?OpenDocument
Apparently, duralite are only for 202 motors. Sure you dont mean another style of piston from ACL?
The only information (cc details etc.) I can find on ACL pistons is their Race series available in 2 styles for the RB30ET:
One with a 4.5cc dish (http://www.aclperfor...rgedPistons.htm)
and the other with a 10cc dish (http://www.aclperfor...orgedPiston.htm)
Key this into my static comp spread sheet above and you get:
4.5cc dish pistons with a Neo head = 9.06 static CR
10cc dish pistons with a Neo head = 8.42 static CR
Of course, this is ASSUMING you have a ZERO DECK HEIGHT on your block and the head is standard item and has a 51cc combustion chamber.
Edited by R32Abuser
Also I have found some conflicting details regarding piston compression heights for some RB30 pistons. Obviously this will affect how the piston sits in the bore and therefore the static CR. So depending on these values the above static CR estimates may or may not be accurate.
This drives home the point to measure everything up before/during the build.
Thanks for that r32 abuser, Them numbers are what's on top of the piston, i typed that number in google and it came up with some one quoting these pistons as acl duralight, I do know that they are acl pistons tho, And that they Are for a rb30et , ok so the head is standard, will just be taking it to head works to get it checked and stuff like that befor I put it on,
And by zero deck hight do you mean the piston being
Flush with the top of the block, ? Because yep that's all been done, and I'm thinking my piston is the 4.5cc dish, now for what head gasket to be used? I'm looking at a steel head gasket but not sure of what thickness
Ok so your deck height is the distance between the top of the piston at TDC and the top of the cylinder as per "deck clearance" below:
Obviously if the piston sits above the cylinder, this will increase the static CR (all things being equal). Similarly, if the piston sits below the cylinder, this will decrease the static CR.
I used a cometic 1.28mm head gasket as recommended in the RB30 DOHC guide. You can also use a standard RBXX head gasket IIRC. Once again, the thickness of your head gasket is going to influence your final static CR so first measure up what your motor has been built to and try a few different thickness head gaskets in a static compression ratio calculator. See what value you get and go from there.
Edited by R32Abuser
Why don't you get your head prepped and cc'ed and double check the deck height and piston dish and tell us what compression ratio you want.
Hopefully can get an answer that won't be a guess.
Agreed.
Ultimately I reckon a stock head gasket will be fine but it is such a pain in the arse if you have assumed incorrectly.
I have a neo head sitting in the garage and I was considering getting a basic RIPS bottom end sent over (which will probably be very similar to your setup) which would comp up nicely with a neo head but I will still double check everything before closing it up.
Bare in mind, 0.020" (aka 20 thousandth of an inch) is only 0.5mm. If those pistons are sitting 20 thou below deck height its enough to shift the static CR quite a bit. In my build its enough to shift the static CR from 9:1 down to 8.64:1.
Food for thought.
This is what I used on my first Rb30 6MKRY9608 http://www.aclperformance.com.au/NissanRB30ETForgedPistons.htm
and these on the 2nd build. that and there like $800.00 from the US or like 1200 if you buy them in Aus. NIS264405i05 http://www.us.mahle.com/C1256F7900537A47/vwContentByKey/W26HSFB8505STULEN/$FILE/2010%20AP%20complete.pdf
I email acl and they for all the info I need in this piston
Bowl volume 12.0cc
Comp Ht 31.10mm
Clearance & Position .025mm At 45.3mm from bottom of skirt
So now saying that my head has about 51cc chambers and block deck hight being 0.5mm what size head gasket will I need to get my compression good
  • 1 year later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
