Hi guys I'm new to this forum,
Ok iv purchased an rb30 block, it's been deck,honed, blue printed, balanced ,
New stock rb30 rods, race bearings, acl dura light pistons ra9301y 1.00 rib 0.025
Iv got a rb25det neo head that I plan on using for the build, I'm wondering what head gasket
I should use? Any info would be great please.
I've looked (for the past 10 minutes lol) for the pistons you state above. I cannot find them.
http://www.acl.com.a...80?OpenDocument
Apparently, duralite are only for 202 motors. Sure you dont mean another style of piston from ACL?
The only information (cc details etc.) I can find on ACL pistons is their Race series available in 2 styles for the RB30ET:
One with a 4.5cc dish (http://www.aclperfor...rgedPistons.htm)
and the other with a 10cc dish (http://www.aclperfor...orgedPiston.htm)
Key this into my static comp spread sheet above and you get:
4.5cc dish pistons with a Neo head = 9.06 static CR
10cc dish pistons with a Neo head = 8.42 static CR
Of course, this is ASSUMING you have a ZERO DECK HEIGHT on your block and the head is standard item and has a 51cc combustion chamber.
Edited by R32Abuser
Also I have found some conflicting details regarding piston compression heights for some RB30 pistons. Obviously this will affect how the piston sits in the bore and therefore the static CR. So depending on these values the above static CR estimates may or may not be accurate.
This drives home the point to measure everything up before/during the build.
Thanks for that r32 abuser, Them numbers are what's on top of the piston, i typed that number in google and it came up with some one quoting these pistons as acl duralight, I do know that they are acl pistons tho, And that they Are for a rb30et , ok so the head is standard, will just be taking it to head works to get it checked and stuff like that befor I put it on,
And by zero deck hight do you mean the piston being
Flush with the top of the block, ? Because yep that's all been done, and I'm thinking my piston is the 4.5cc dish, now for what head gasket to be used? I'm looking at a steel head gasket but not sure of what thickness
Ok so your deck height is the distance between the top of the piston at TDC and the top of the cylinder as per "deck clearance" below:
Obviously if the piston sits above the cylinder, this will increase the static CR (all things being equal). Similarly, if the piston sits below the cylinder, this will decrease the static CR.
I used a cometic 1.28mm head gasket as recommended in the RB30 DOHC guide. You can also use a standard RBXX head gasket IIRC. Once again, the thickness of your head gasket is going to influence your final static CR so first measure up what your motor has been built to and try a few different thickness head gaskets in a static compression ratio calculator. See what value you get and go from there.
Edited by R32Abuser
Why don't you get your head prepped and cc'ed and double check the deck height and piston dish and tell us what compression ratio you want.
Hopefully can get an answer that won't be a guess.
Agreed.
Ultimately I reckon a stock head gasket will be fine but it is such a pain in the arse if you have assumed incorrectly.
I have a neo head sitting in the garage and I was considering getting a basic RIPS bottom end sent over (which will probably be very similar to your setup) which would comp up nicely with a neo head but I will still double check everything before closing it up.
Bare in mind, 0.020" (aka 20 thousandth of an inch) is only 0.5mm. If those pistons are sitting 20 thou below deck height its enough to shift the static CR quite a bit. In my build its enough to shift the static CR from 9:1 down to 8.64:1.
Food for thought.
This is what I used on my first Rb30 6MKRY9608 http://www.aclperformance.com.au/NissanRB30ETForgedPistons.htm
and these on the 2nd build. that and there like $800.00 from the US or like 1200 if you buy them in Aus. NIS264405i05 http://www.us.mahle.com/C1256F7900537A47/vwContentByKey/W26HSFB8505STULEN/$FILE/2010%20AP%20complete.pdf
I email acl and they for all the info I need in this piston
Bowl volume 12.0cc
Comp Ht 31.10mm
Clearance & Position .025mm At 45.3mm from bottom of skirt
So now saying that my head has about 51cc chambers and block deck hight being 0.5mm what size head gasket will I need to get my compression good
  • 1 year later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
