We ate at Chedi Thai Restaurant in Newtown not that long ago and is the best Thai food I've ever eaten in Australia. We found out when paying that the owner of that actually owns the place where we stay every year in Thailand so I guess that explains a bit :)
Here's their website for anyone interested http://www.chedi.com.au/
Newtown and Glebe are real Meccas for food assortment eh?
Al Mustafas in Glebe is good traditional Lebanese food, Glebe is good....But the price tag that comes with it i not so keen on.
Give me cheap dingy place with mumma out the back cooking any day of the week,
Got my Cabramatta fix yesterday, That will get me though the week
do they have shisha?
^what did you eat there?
60$ for a 'larger' plate - how large is it!?
yeah not so cheap, one for when you want to treat yourself. Good selection of modern cuisine that has fun with flavors.
We had two starters, three small plates, side plate and two desserts between us, plus a jug of sangria, both us where very very full. It was more then we needed but we don't do it very often so wanted to take full advantage.
Not sure how big the larger plate is but at a guess a larger with a side would be good for two. Definitely food designed to share.
Try the Bounty for dessert, loved it. Bed of chocolate mousse, balls of coconut ice cream, shavings of toasted coconut and wafers of chocolate.
hmm hungry now
Just had Jimmys cafe and Grill in Emu Plains. Deluxe eye fillet was pretty amazing. Meals looked a little small but struggled to finish it. Definitely worth a go.... We had the added bonus of watching some poor buggers BMW X5 burn to the ground next to Pauls Warehouse.
So if we park Maria's 530i there whilst munching at Jimmy's it could end up the same way?
  • 1 month later...
So Im gonna be up there for texi this weekend, anywhere good to grab a feed around that area? Im not a Sydneysider so reading through this area I wouldnt know where most of the places mentioned are
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
