5 minutes? That's a bit modest I am sure they can crack ten seconds.
10 seconds is way too quick for my car. It takes me at least 3 minutes to connect up the battery, another minute or so to get out the driveway. No, I stand by original time - somewhere in the 5 minute mark.
Oh, it's that video ...... Again :P
Better add something constructive. Has anyone with a nm35 used that little iPhone app? I have no idea if accurate, but I think my 7.4 was plausible when non turbo.
It's free just grab it warm the car up and go do it! Post result.
That's fine but I know what it displayed. ~6 secs isn't very quick. When I do it again I'll video it for you.
Sorry, should have been more clear. I don't doubt that is what you read off the display, you have nothing to gain by fibbing about it! I doubt that the gadget is accurate. Out of all the nm35s I've been in, not many feel like 5 second bracket cars. With only a filter and spacer, I just don't see it happening especially with the brake restriction still there.
5-6 second 0-100 is very plausible with a dead stock car IMO! Under that I would find hard to believe.
Pocket Dyno was the app I used. Dead stock (nearly 2 years ago) it said 7.2 sec.
Same road but with mods (stock turbo but full exhaust, intake, shift kit & brake wire mod) plus passenger was 5.7's.
I haven't tried with new turbo.
I agree Craig, 5-6 seconds is very plausible with a dead stock car, just not a dead stock M35 :)
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
    • Do you have any before and after photos? That's $200 just for the hydro blasting?
    • It doesn't look like there's a lot of options out there these days, and what's out there is performance oriented aftermarket stuff (with the GTR markup) I wonder if there are other cars with similar springs, after all its just a matter of length, diameter and stiffness. Alternatively, I did see coil spacers. Probably not the best option, but could be serviceable too.
