My question would be if cars with minimal mods are doing 6 second flat (or under) 0-100km/h, then why are the 1/4 mile times not displaying that. If your doing a 0-100 in 5.9, then I would have thought the quarter would be a lot faster than 14.6
Example- humor me.
03-06 350z. Accepted to do a high 5.# second 0-100. Does a quarter in around 13.6 to 13.9. Stock.
Anyway, just my opinion. They might be going faster than I thought.
See what "the stag wagon" comes back with!?
That's because they're not doing sub 6 sec 0-100 times, lol.
I have no idea if the Pocket dyno is accurate. I only used it because a) it was free & b) a reasonable form of comparison. It tells me that I dropped ~1.5 sec from one test to another, but in the real world I could have dropped from 5:00 minutes to 4:58.5 (sic).
Hand timed runs or phone apps are useful but not a proper comparison across cars/driver/location. Need a drag strip or other fancy electronic timing for that.
Yeah, it is debatable. And its all been done before. Some people would remember the M35 vs VE sportswagon thread, where a road test claimed that a stock M35 would do a 13.5 quarter, and 0-100 in 5.7 secs. lol- I'll buy that one!
Have to strap on some high end accelerometers and get a real figure if we want to end the debate. Really, does it matter? We have a good range of 1/4 mile times, and hopefully some really fast ones too once Scott gets his back together, and sky^rit as well. So we can compare them, and there is no error or subjectivity with 1/4 times. :)
Went on u tube found a 2002 ar/x in Russia doing a 0-100 showing the speedo dash only so being bored I did 10 stop watch times on it and got an average of 6.5 it sounds about right. Giving the amount of n m these cars have.??????
awd does count for a fair bit on 0-100, but not so over a 1/4m. My s1 c34 0-100 started in the low 7s std, and did a 5.99 before it went pop, using a HKS hard wired timer! Will see with the new motor, low 4s hopefully?
With a highflow the 0-100 times will usually be slower, that is assuming both turbo's are tuned properly and run the same mods. It's only past 50kph that mine would start to wind up and by then the stocker would be 2 or 3 car lengths in front.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
