Hi,
I have a R34 Gtt with a Z32 AFM, I removed my AFM and found that the mesh on the back of it was badly damaged, so i removed it all together (The rear mesh only, front mesh is fine), i also sprayed some Electra-Clean spray on the AFM wires and screen to clean it.
I reinstalled the afm and now the car will not run.. It starts and dies almost instantly, if i use any throttle it dies even quicker..
To remove and install it i had to remove a few hoses going to the inter cooler, but i have checked them all and they don't seem like they are leaking..
I have tried starting it with the AFM disconnected and it was the same..
I am thinking that i have either damaged the AFM with the electra-clean (Although it is made for cleaning electrical components??)
Or that i have a boost leak, although it would have to be very bad for it to cause the car to not even idle.
Car will still idle with a boost leak, it will hunt badly while idling. It should start and idle though with the AFM disconnected (limp home mode).
It's likely the solder joints need re-doing on the AFM, or the AFM plug needs to be fixed/replaced. Are you sure you didn't leave a rag or something in the piping?
Why did you remove the AFM anyway?
Im not sure what you're saying? Im actually not sure what ECU it has, it already had the Z32 AFM on it when i bought it, and never had any problems so im assuming it it was installed correctly.. It must be from something i have done when removing the afm
If you do have a stock ECU, you could try disconnecting the battery and pumping the brake pedal to get all the charge out the system so the ECU has to re-learn timing etc. If you have a aftermarket ECU like a PowerFC this won't do anything.
If you are running a Z32 AFM on a untuned stock ECU, your spark plugs will be completely black from overfueling (once they're fouled to hell it's difficult to start an engine on them), pull one plug out or all them out and take a look.
The splice job looks fine..
Its not like i have just installed the AFM, it was on the car fine and i just removed and reinstalled it and now its having problems.. And i thought that trying to start with the afm unplugged would eliminate any afm problem?
The factory plug doesn't fit a Z32 AFM, so a Z32 plug needs to be spliced into the existing wiring. scotty is just suggesting to look at the splicing, whether it was properly soldered or wires just twisted together with electrical tape wrapped around is the question. At the splice 2 (or more) wires that shouldn't be touching might be touching (especially if just twisted and taped). You might have to do some poking around with a multimeter at the splice and at the plug.
If the mesh was screwed, it might have even been a fake Z32
Yeah i understand about the splice, i checked the connections and they are soldered and individually heat-shrunk..
Im still not understanding how the afm could be the culprit if it still wont start with it unplugged?
And how can i tell if its a fake Z32 AFM? , i have already checked the sticker and part numbers and they seem genuine..
Thanks for all the help so far
If the connections look fine at the splice and the ecu and the plug isn't corroded then you have no other choice but to test another AFM, I have one here you can try but where are you located?
i just dont see how the wiring or Plugs could foul just from removing and reinstalling the afm?
I checked the AFM voltage on The power FC, and while the key was "on", and for the very brief moment while the car idles it read
"10-15MV" and in the sensor check it said AFL.01 V
I have read that it is meant to be .3V, but it is a very small difference, could this be a problem?
    • Had a go at the stuck crush tube this afternoon. Tried things like grips and a chain wrench first but wouldn't just twist straight off. So got to work with a drill. Started small and kept a depth stop on to make sure I didn't drill into the bolt. Made a line of drill holes all the way up and enlarged them. Then a combination of chisel and Dremel to split it all the way up. Levered the split to get oil in there and eventually it gave a bit while levering. Worked it back and forth with loads more oil till it was spinning freely, then with grips I could work it downwards and off. And no significant damage to the bolt (not by me anyway - just the 27 years of rust)
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
    • It sounds farrrrrrr too cold at your place Duncan... Here I was thinking our 10 degrees overnight is getting cold...
    • oh yeah, reminded this morning....bin lids frozen shut too
    • In my case not, because of total reno. But yeah.
