i got 135ish across the lot which i thought was a little low, but it seems to be the norm, im running a fully built engine using cp flat tops, an a standard 26 head that has been fully reconditioned buy advan, only mods to perfomance side if the heas is adjustable cam gears
Well its reassuring to know I am not alone but in hindsight I would have preferred to get the 9:1 pistons but they were not available in standard size and would have involved a lot more expense. 9;1 pistons with a Neo head would be great and with a 26 head even better - maybe next time!
So what power are you making with your low compression and 26 head?
the pistons dont make the compression ratio
bore x stroke = SV
piston to deck height + gasket bore x gasket thickness (+ piston dish/ valve releif) or (- piston dome) + chamber cc = CV
sv + cv ÷ vc = static compression ratio
Either some piston suppliers are telling porkies or you're mistaken. If you have two pistons with generally the same dimensions and pin position etc then the one with a domed or raised part (various shapes are used sometimes with allowance made for the valves) crown will have a higher compression ratio - the swept volume will be the same but the volume of the chamber will be reduced by the amount the crown intrudes into it ergo higher static CR.
in my trade i need to know how to do things properly
piston manufacturers will state "x:1" compression similar to cam manufaturers saying stage or type cams
they assume your measurements and specs will match theirs
they also assume the person who assembles will measure it first
here is the actual formula in full
Swept Volume
Bore x Bore = Answer1
Answer1 ÷ 4 = Answer2
Answer2 x π (3.142) x stroke = Answer3
Answer3 ÷ 1000 = Swept Volume ( SV )
Compression Volume
Head CC +
Piston dome - / dish volume +
Deck height (piston below the deck)
Answer2 x π (3.142) x block deck to piston crown measurement = Answer3
Answer3 ÷ 1000 = deck height volume
Deck height (piston above the deck)
piston measurement above top ring land x piston measurement above top ring land = Answer1
Gasket
Gasket Bore x Gasket Bore = Answer1
Answer2 x π (3.142) x Gasket thickness = Answer3
Answer3 ÷ 1000 = Gasket volume
The Maths
Head CC + gasket Volume + Piston dish Volume(- Piston dome volume ) + deck height (-if piston is above the deck)= CV
SV + CV + Answer
Answer ÷ CV = Compression ratio
Example
my motor
87 x 87 = 7,569
÷ 4 = 1,892.25
x 3.142 x 85 = 505,363.2075
÷ 1000 = 505.36321 (sv)
Head CC 53.4
Piston Dome -10cc
deck height, piston above
0.005" ÷ 0.03837 = 0.127
86.1 x 86.1 = 7413.21
÷ 4 = 1853.3025
x 3.142 x 0.127 = 739.53071
÷ 1000 = -0.73953
head gasket
88 x 88 = 7,744
÷ 4 = 1,936
x 3.142 x 1.5 = 9,124.368
÷1000 = +9.12437
53.4 + 9.12437 - 10 - 0.73953 = 51.78484 CV
51.78484 + 505.36321 = 557.14805
÷ 51.78484= 10.7589 aka 10.75:1
Just so you don't confuse the punters you will agree that you can use the tables supplied by the piston manufacturers/sellers to work out which will give the higher compression ratio e.g. Spool sell pistons for the RB30/26 - one labelled 8.2:1 CR and one labelled 9:1 CR and the latter will result in a higher static CR which is all that I was saying (I wish I had the higher compression i.e. 9:1 pistons).
You are quite correct to say that the resulting static CR will not necessarily be exactly 9:1 as there are many variables but you will agree that just changing the piston specs can increase the CR.
i will NOT agree in saying that to buy a piston based on its stated compression ratio will ever be true,
I will also NOT agree to use their tables, that is guessing, i will actually use measurements that i personally measure myself, this eliminates variables, which when a company says that it has too many variables it means "they have no clue they just bought them from someone else" or "check everything is right cause we just told you how we are not liable for you purchasing the wrong pistons if you dont measure everything"
the formula is used with measurements taken from the piston, block, head gasket and cylinder head that those pistons are going into, not just 1 item, not someone elses parts or measurements.
This is the only right way, its only "too many variables" if there is a lazy engine builder or a company avoiding liability, why spend big money to guess?
sure the pistons with the higher comp ratio stated might be true in saying it will be higher, thats still a guess as to how much higher
can you garantee the head chamber isnt 61cc's where it should be 64? or is it 68 instead?
1mm head gasket not available but a 1.8mm is?
piston sitting 10 thou above before its been ground during a dummy assemble, was it ground and tunnel bored before?
you measure and calculate your comp. dont read what is on the sheet in the box
with engine building your either precisely spot on or your wrong and something will f**k up eventually
very interesting guys, so many factors involved to build a quality engine, at the moment i am on a sort of run in tune. eg: ive done a bit of running in on a softer tune but now im doing some more with a slightly more aggressive tune, all though still a very soft tune... anyhow im makeing 317rwkw on 17/18 psi, as soon as i get some more cash im going to play around with my fuel system setup, prob get a larger surge tank an run a areomotive a1000 + change my fuel lines to teflon speedflo, after that im hoping to make at least 400kw
This is getting tedious but I hate being misrepresented.
I never said that the stated CR on a box of pistons was 100% accurate. I just said that you could use the manufacturer's listed CRs as a guide.
Your impressively long formula will not give a 100% accurate CR either because of the irregular shape of most compression chambers and some piston crowns and the variations in the compressibility of the head gaskets etc. The correct measurement is actually quite simple if the spark plug hole is at the top centre.
With the engine fully assembled put the piston at TDC. Using a pipette measure the amount of liquid needed to fill the combustion chamber and subtract an amount equal to the volume of the part of the spark plug if any that protrudes into the combustion chamber (quite easy to determine). Call this volume x
Take the piston to BDC and measure the additional amount of liquid required to fill the cylinder to the top of the combustion chamber. Call this volume y.
The static CR is (x+y)divided by x
The product of this calculation will be sufficiently accurate for most purposes.
Well you're doing better than me - so far I only have 230awkw at 15psi. I have a GT3540 with .63AR. I will be getting it retuned soon to whatever it will take - probably around 25psi and I iwll be happy if I crack 300awkw. If you have a similar compression and turbo your extra power must be down to the RB26 head or do you have twins?
using it as a guide is still wrong, you know how many people argue that i cant have 10:75:1 because someone else has a dome thats bigger then the one on my piston?
but yeas, i agree there, that is another more correct method and that would be just as accurate as measuring everything before it is put together, X is your CV and Y is your SV+CV, they do that with alot of the race cars to make sure they are within spec of the rule book
using a burrette you can also measure a combustion chamber or an eye dropper if you dont have one 1mm = 1cc
same with the piston, if its a dome, use play dough
and you can actually measure the squash of a head gasket with the right measuring tools, average it is about 10 thou, but that is a guess i still wont use
lol shall we go into dynamic compression and volumetric efficency?
sorry about whoring your thread zach
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
