Hey guys,
I'm selling a Bee*R rev limiter and HKS Type 1 Turbo Timer. Both have very little use and is in as new condition.
Will post either item for $10 Australia wide.
I'm located in Perth and am after $140 for the turbo timer and harness and $200 for the Bee*R.
Thanks
Hi, would the rev limiter work on R33? I know there are different types out there.... What did you have it on? Was it good or did it destoy turbos, exhausts?? How hard was it to install?
Cheers.
Yep would work on your R33. This type will work on all Nissans for that matter. I had it on my R32 GTR for about 18 months and 5000kms. Never had any problems with it on my car. Only removed it and the turbo timer because I'm stripping my car to lose as much weight as possible. It's designed to stop the motor from leaning out when it hits limiter and provides a great launch control as you can adjust it to your desired launch rpm and it builds boost whilst you're free revving. Really easy to install if you have basic mechanical and soldering skills. I can link you to install instructions if you'd like.
Hope this helps
Wow, you must be serious about stripping weight... how much do these items weigh? lol. Sweet dude, let me think about it, how would you want payment?
Haha yeah I'm getting pretty serious about losing all the unnecessary weight in my car. Have already removed all the hicas, air con and all unused wiring from the wiring harness. sound deadening will be next to go. every little bit helps haha.
Hks timer is sold pending payment clearance
  • 1 month later...
    • So, what did you decide? If these items were going in and out of stock, you could at least order the two in-stock pieces. Also, I'd say the stock bit of airbox isn't that restrictive to your NA motor. To test if it is, fit a vacuum gauge between the airbox and throttle body. At WOT do you measure any vacuum?
    • Hey guys I have a 2001 Nissan stagea vq25det, I don't have any engine lights and not really any issues running but I was curious to see if I could use my obd II scanner to find anything that was hidden and I plugged my scanner in and it just said "Low voltage cannot scan" does anyone know how to fix this or what this could be?
    • Sadly we have something in common, our Skyline's like blowing up electrically 馃槩
    • So, no videos, but, the FAB9 Elite manifold and 68mm Bosch throttle bodies are in stock, but, not the rear part of the air box The FAB9 rear airbox thingie is made with a 3" intake pipe, to suit the 3" intake pipe size of a 68mm throttle body  When they get some more in stock is currently unknown as I'm waiting for FAB9 to reply with a ETA on resupply, my assumption is they outsource their plastic printing stuff to "china", and with the current "tariff war" going on in 'Merica it could be on hold for an undisclosed time Should I pull the pin on the Intake and throttle body, and wait for the airbox?????, that's what I'm thinking... 1. Would the standard 2.75" OEM intake on the air box really be that much of a restriction compared to the 3" naturally aspirated?????? 2. If I don't get the 3" FAB9 airbox fitted at the same time as the intake and throttle body will it need a retune, when/if it eventually turns up?????? As I'm impulsive, to a fault, decisions will be made within....."what's the time now"???....let's say 12 hours......LOL
