Hi guys,
im looking at upgrading my fuel pump but im not sure which one to choose..been informed that a bosch 040 or a walbro 255lph is the way to go just thought id see what everyone else thinks. heard people are selling the ones mentioned above for 044 and stuff.
if anyone could point me in the right direction would be much appreciated. Also what injectors i should get.
thanks
https://www.sau.com.au/forums/topic/402104-r34-gtt-fuel-pumpinjectors/
You need to tell us what you are doing, or trying to achieve with the car? What are your power goals for the future? What fuel are you running on? What mods? Etc etc
i honestly dont know what im trying to achieve, current mods are poncams, z32, fmic, exhaust turbo back with hi-flow cat. im thinking of getting a t04z turbo but have no funds at the moment. basically the since the valves are open for longer i figured they need more air and fuel so i bought the z32 afm just unsure what size injectors and fuel pump to go to.
just thought id bump this instead of new thread. ive got 34 gtt too with fmic, turbo back exhaust + nistune.
will be happy with a figure around 260-280rwkw. won't be chasing more than this in the future.
need some advice on the following:
injectors - what size should do for this power?
turbo - thinking a GCG highflow (would like to keep it discrete / looking stock)
fuel pump - what should support this power?
Some Nismo 555's will be fine for that, and have possibly enough room for some E30?
Fuel pump, any of the ones mentioned will work. Depends on how much money you want to spend. The Nismo pumps are great, and are plug and play.
Walbro (i have on) are fine. Am using it for 280-300rwkw dyno dependant, on the track and daily driven. Easy to install and cheap.
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
