You want to re-thread the tank? It is just the screws that strip I think, just get some off a v35 wreck or something? I have a few here if you get stuck.
I have to look at redesigning my fuel system, specifically inside the tank. I need an in-tank surge assembly using another pump to feed the twins in some kind of container, hopefully that will allow me to run the tank to a lower level without running lean around corners.
  • 1 year later...
  • Replies 65
Dose anyone else s pump have 3 positive wires and 3 negatives all joined up like this? also sounds like the pump ramps up and down according to throttle position?
this is what i ended up doing have a few things i want to run in the back so figured id put a bigger cable in.
You shouldn't need another pump if you can make something to contain your pumps that has one way gates on it (to let fuel in but not out - similar to the one way system on some sumps)
i was going to use it to turn the pump on and off with the old power cables
Looks good Dale, the stock pump does indeed drop voltage at idle and cruise to limit the flow, so the fuel doesn't overheat. Unfortunately the new pumps require more voltage, hence the need for the rewire. Are you mounting the relay under the seat there? What happens if a big bloke sits there, does the seat touch the relay?
Did you use the DW300?
Is that the stock pump you are running?
If so, be careful putting it on full 12V power. I know others have & not had a problem, but that was how I popped my motor. The pump would intermittently make a noise (sort of a buzz) & I suspect when that was happening it wasn't pumping right. I found out by going wot & the rest is smoky, rattly history.
yep i used the DW300, went in easily enough. so you reckon i can just pop the relay on and energize it off the old feed then the pump will run full ball all the time when the car is on, this is ok for the car/pump? atm its just running off the stock cables. yep it touches the seat a little it lines up with one of the box sections under the seat tho. if i sit on it i cant feel anything and im a 100 odd kgs or so haha
nup its the DW300 been in a few days running off the stock power cables seems all good so far
^ OK, all good. Do you notice it running richer at all?
yep its running quite rich atm but its always been like that i haven't noticed it change much so far with the new pump. needs a tune and a ecu for that matter lol! still searching for a fcon harness
Why would it run richer? Surely the stock fuel pressure reg can keep up...
Definitely something you want to do before a tune, I have seen so many people fail on the dyno due to fuel supply issues and not having the pump hardwired, such a waste of time and money.
Good luck with the harness! What if I was to say there is a better alternative out there.
Better option? I wouldn't go that far yet... I am still learning the myriad of options the Fcon has to suit our cars, if only there was HKS factory support, like they have in NZ...
Yea scotty!!!
maybe talk to Stupidious!.....sorry Sidious!
I'll use my local support. :P
Dunno, but I noticed mine was a little richer when I put the stock pump on full 12V (at least when it wasn't buzzing).
What is this factory support you speak of haha
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
