I posted this topic on G35 driver and i thought i'd post it here too, if anyone has done the bolt replacement in the lower rear control arm PLEASE let me know your help would be greatly appreciated.
Here is the post on G35Driver -
Okay so i have a 2003 Nissan Skyline V35 350GT Coupe, as most of you would know it's the equivalent of the G35 Coupe.
I purchased the car a few months ago privately, at the time i was told of the problem but was assured it was a minor issue and i even got a full inspection from a mechanic who confirmed it was nothing to worry about for a while.
3 Months on and the problem is getting worse. What's happening is when i turn, i hear a creaking noise in the front left suspension (which i have confirmed is the problem as there is a stripped bolt right through the lower rear control arm) and it's driving me insane. The roads are VERY bad where i live, so this problem is getting worse quick and i need it resolved ASAP.
So now i am going to Nissan first thing Monday to find out the order number for the bolt and do it from home, i just wanted to know if anyone has replaced this bolt before and could help me out.
Thank you!
https://www.sau.com.au/forums/topic/402142-suspension-issues-please-help/
Sorry, this is a bit confusing- is it the front suspension, or the rear?
Hope you sit down when Nissan tell you the price, if its what I'm thinking it is. Get a Picture- tells 1000 words as they say.
Search for superpro bushes. they do a range for V35s now, and should be able to get the suspension bush. Its genreally not a "bolt" thats an issue, its the rubber around it.
It's confusing for me too, when i originally took it to Nissan the mechanic was very confusing and sent me to the panel beaters to get it done (i went there and the guy laughed at the dick head mechanic for sending me to him)
I'm near 100% sure it's the bolt itself, the bottom of it is completely stripped but it's very hard to see up there as I've only got a jack.
Ok, so I had a quick look on mine. That's the bit that goes up and supports the bottom of the shock. I'm not sure if you could press that bolt out or if it's in there permanently.
If it was mine, I'd just get a wrecker part off z33 or v35, just the whole bit. But by all means speak to Nissan if that's your plan. Make sure the rubber bush hasn't flogged out since its been moving round.
There are a few bushes that flog out on these cars, and most people don't realise.
Thanks for your help man, if Nissan decide to charge me an arm and a leg for the part then i'll go down that track. Yeah when i originally bought the car with the RACQ inspection the inspector commented that all bushes were fine.
If its the bolt that's stripped, then youll need the replacement. But just so you know, that bush is know for getting destroyed as well. Might be a bush issue, might be a stripped thread issue. Just get under there and find out. I reckon 50% or more cars are driving round with the bush not 100%.
It's not the bolt in the hub yeah, it's the other end that bolts to the rail?
At least you have pin pointed it, good luck mate.
Yeah that's the plan for today get under it and double check. In that link you gave me with the diagram, where it has the part #15 it's actually the "king pin" bolt on the other end that's the problem. Yeah i agree i have heard that before bushes getting worn easily apparently there's some high quality ones that can last 100,000KM.
As I said earlier - superpro for the bushes
And you can get improved castor bushes for better handling :yes:
But unless you have a press, its not a diy.
I bet someone has gone to replace the bush, and through f it, too hard, but it back on and cross threaded the bolt.
I can get access to one so i should be sweet. Yeah i brought it up with the previous owner last night and he claimed to have no idea but you never know.. I'll see how i go with Nissan, just realised tomorrows a public holiday and i'm back to work Tuesday so it won't be done for ages f**k.
Nissan don't sell many of the bushes or links separate - the lower control arm itself (no. 10 on the pic) is a consumable part, and they do not sell the shocker bush or main bush - you have to buy a whole arm (rrp $500)! I bought some Nolathane bushes and pressed them in last week (see photo below). When I pulled the lower control arm off I realised that the lower ball joints are stuffed too - and guess what? Nissan don't sell them either - they only sell the whole Number 1 on the pic assembly at $1k a pop. Luckily I found some ball joints online for $60 per pair delivered.
For the record, by my memory (given had the car apart last week) our 2 wheel drive V35s don't have that No. 15 part! Maybe I am wrong though.
I am willing to bet that your noise is either the lower control arm bushes or your ball joints.
And reading through your post again, I think you might be talking about the sway bar end link where it bolts onto the lower control arm. To fit these properly you need to lower the car onto bricks or something to lift up the upper control arm to the sway bar end link, to make the holes line up. If you just try to screw the bolt through without it being lined up perfectly, you shave off the bolt thread. This is what it sounds like has been done to yours. Luckily these are a common part between pretty much every Nissan, and are cheap. I replaced mine a while back on my R34 and they cost stuff all - maybe $50 a pair from memory.
Memory might be a bit hazy then - its there on your car.We came to the conclusion that the stripped bolt was the one in the Chassis (thats what OP confirmed) at the rear end of #15.If that is the cause of his clonk/squeak - I'm not that confident. There are a lot of things under there that can squeak! And I bet more than one set of bushes are history, after him saying that he drives on very rough roads.
Thankyou for your replies helping me get to the bottom of this, i took some photo's today of the bolt that needs replacing. I've checked ball joints they're all good.
My big issue is that the top of the bolt is tucked away behind the panel you can see in the first image, making it impossible to get to without removing the panels. This is becoming a really f**king annoying drama that no one in my town seems to know how to fix.
  • 1 month later...
Been reading through all these replies again, it's the lower control arm bushes that are farked. The compression rod bushes are worn too. I've ordered the comp rod bushes off ebay for $25 and im about to buy the lower rear control arm bushes for both left and right suspension. Now after changing all 3 of these bushes i should be sweet, oh and knock that stripped bolt out and replace it.
Cheers
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
