The photo I posted is one with ambient temp.
You could change the face plate, but is it easy to find?
The climate control unit is only $150 and it's plug and play so I just thought itd be the best and easiest method.
  • 1 month later...
Hi everyone,
Have just finished sourcing all of the required parts for this conversion.
For future reference, if anybody has the same factory GTR NAVI unit as mine - for clarification, the side brackets are definately different and you need to also source the double din brackets.
If anybody is actually interested in a full kit - PM me as I have one with everything you need which I am thinking of selling - Brackets, brand new genuine nissan double din facia / surround, air con unit with brand new genuine nissan replacement front face. The whole kit literally looks brand new.
I'm still tossing up whether to put it in my car or not.
Cheers.
  • 3 months later...
  • 1 month later...
Its already double din iso ( tiny bit off double din todays standard but not much to worry about )
No kit needed but some trim rings wont fit right without filing the trim ring slightly or some dont need trim ring mounted , only slot the existing holes in the cage holding the radio to set it back a bit further to make it look perfect
Note tape a thick soft towel around the console / gear surround to set the razor sharp cage on or it farks the surround black bits and its near impossible to repair ,
Double din rules fark the single din look is boring
made this mistake doing my double din conversion drunk, was too over excited when it finally got delivered now scratches everywhere :( will probably get it repolstered
  • 5 years later...
I would be interested in purchasing any of the mentioned parts including the 2 DIN brackets and the facia and the new faceplate for the ambient control version of the heater control.  My gtr has the sat nav aswell and I'd like to convert to the 2DIN setup.
Thanks!
Sean
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
