OK so any of you that know me know i have had issues with my car on boost, these were all boiled down to fuel delivery issues.
my car was cutting out round corners and running lean on the dyno over 5000rpm, anyway the culprite was my BOSCH 040 intank fuel pump, it was extreamly clogged, the mesh cover was caked and the filter was clogged, so i replaced it with a new one.
this one has been in my tank for about 2 months and it has fallen to the same fate, unfortunatly the Bosch pumps do not have a servicable filter and i assume the internals have been damaged anyway as the pump has become noisy again.
so im going to replace it AGAIN with something different, just for funzies. anyway obviosuly my tank still has shit in it.
i could get the tan kcleaned and try again but i am sick of going through pumps. i do not know if its just debris in the tank or if its rust from the old tank. SO
i have sourced a GTR plastic tank W straps, i still need a sender,
1st question......
with the larger GTR tank and new sender unit, what is involved in getting this to work with my stock guage?
i have also sourced some new gtr injectors (i already have these installed but they might be farked) new ones have been flow tested and cleaned....
what else appart from the fuel filter should i replacein the fuel system? any lines, any bottle neck which may have been affected by the crap going though my system?
https://www.sau.com.au/forums/topic/402153-fuel-system-clogged-to-shit/
Are u sure crap has gone through the system or just in the pumps filter and possibly fuel filter?
Mates 34 did the same thing. He ran the fuel in the tank through a fuel filter and into some jerry cans a few times to remove the debris from the tank. Hasnt played up since
well i have destroyed 2 fuel pumps, while i have half the system out i might aswell replace anything else i can, dont want to lean out pushing 1bar boost at 6000rpm again, bad sensation when it chokes
No offense but that
Seams like the worst answer. I'm happy to get a new pump and tank, do it properly, I'm even getting cleaned and flow tested injectors incase their not %100, why would I just keep going through pumps at $200 a pop and get rid of filters? I don't want old tank crap getting past the filters I want their to be no crap.
  • 1 month later...
I have a R34 with the same issue as the OP - Except I've gone through pumps in as little as uh, one day.
I was able to take the pump out, clean the mesh with it (Bosch 040) and put it back in and suprise suprise, it actually worked...
...until today, where it is again groaning and carrying on.
The above solution from Jez sounds like it's something to try, at $200 a pop, I can't afford a new pump every couple of days, but I CAN afford to buy like five fuel filters and some jerry cans and pump the tank through them and rinse/repeat instead of obliterating the mesh in the pump and killing pumps over and over.
Just cut the mesh out the bottom of the 040
Pump
And Just replace filter a lot more often.
While this sounds like the ultimate backyard fix, um.. would this actually work? Any thoughts? Its much, much, much easier to replace a filter in the R34 than the pump. (and especially the tank)
How often is often? 5k kms? Or is this option just madness?
Happy to do either or both, really, really tired of replacing fuel pumps.. twice a week.
Seriously. It is an utter bastard on the R34. So much so I'd almost rather spend $1200 on fuel pumps lol. I'll try the filter and jerry can thing and post here just incase some poor soul has this problem and searches the forums and finds this (like I did)
I removed the mesh on 040 worked well for me
No issues I did a filter on every service
5000kms
Just comes down to what your prepared to do
I cut mine off as I got sick of pulling pump to clean it.
Dare I ask what the best way of removing this is? I tend to replace the fuel filter when I replace the oil filter anyway (i.e every 5k kms), because it's .. right there, and costs like $10.
I've only cleaned the pump out, but never really attempted to cut the mesh.
Cant' you flush the tank while it's in the car ? Pull the lines out the bottom and bung up. fill the tank with a suitable solvent (I'm going to say ethanol) - but REMOVE the fuel pump first !!!!
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
